Flaming Modules
Old Jul 19, 2003 | 02:11 PM
PONTIAC86style's Avatar
Car: Pontiac Firebird
Engine: 2800
Transmission: slushbox 700r4
Flaming Modules
what else burns up an ignigtion module other than, lack of the grease, and a bad secondary ignition?? please help, wasting money over here!!
Old Jul 19, 2003 | 09:20 PM
89V6FBIRD's Avatar
Car: 1999 Pontiac Trans Am
Engine: LS1 - 346 ci
Karl's alternator fried his ignition modules. It was overcharging, too high of a voltage.
Old Jul 19, 2003 | 10:09 PM
Engine: 2800
is there a way to check/adjust the voltage on my alt?
Old Jul 19, 2003 | 11:57 PM
89V6FBIRD's Avatar
Get a voltmeter and check voltage when car is off. It should be around 12. When the car is started, the voltage should be max 14.4, anymore and its too much and the regulator inside the alternator is shot. You'll need a new one. If so, get the lifetime warranty one.
Old Jul 22, 2003 | 12:03 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
13.8 volts is usually what you'll find with the engine running.
You can also toast a module by leaving the key in the "on/run/test lights" position for a long time without the engine running. If you want to listen to the radio with the car off, turn the key backwards to the "accessory" position.
InfernalVortex
Apr 20, 2021 11:31 AM
2012sergen11
Oct 13, 2015 07:38 PM
dusterbd
Sep 29, 2015 08:40 AM
AmorgetRS
Sep 28, 2015 09:33 PM
tattmann
Sep 27, 2015 05:20 PM
