A/C question...........
Old Jul 22, 2003 | 04:24 PM
camaro123's Avatar
Is any problem to the computer if I take all the A/C crap out of my camaro??? or that does it affect the computer???
Thank you in advance
X
Old Jul 22, 2003 | 05:39 PM
socialdeviant's Avatar
won't do a thing to the comp...
I am not sure how the fan is switched on when the AC is on, but I think its pressure oriented.
Old Jul 22, 2003 | 05:53 PM
camaro123's Avatar
I hope so, because is only weight on my car and I want to get some out.
Thank you for your answer
X
Old Jul 22, 2003 | 07:45 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Yep its cool. I ripped all of mine out and the car is much happier.
I did remove the parts nicly but I removed everything not important and just dead weight.
Matt
Old Jul 23, 2003 | 12:15 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
There's a sensor that you'll need to stick a wire into... it's the a/c hard line that's bolted to the passenger side's main frame rail. That's the high pressure switch- it opens when there's high pressure, and turns on the fan. So when you unhook the connector, your fan will come on (when the engine's running). So just stick a piece of wire into the connector.
Otherwise, no problems except for an ugly looking "empty" a/c compressor bracket! I've driven my car without a/c since 1996...
Old Jul 23, 2003 | 12:57 PM
camaro123's Avatar
a/c
Ok, Thankx alot, I think is a couple of pounds that I get rid of the front, right???
Thankx guys
X
Old Jul 23, 2003 | 01:55 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Sorry I forgot about the fan swtich thingy ma bob.
My computer doesn't control my fan anymore.
Matt
Old Jul 23, 2003 | 06:03 PM
camaro123's Avatar
a/c OUT!!!!!!!!!
Ok, the a/c is out everything is working good and the engine idles better now than before.
Thank you guys
X
jrdturbo
Mar 31, 2016 02:58 PM
2012sergen11
Oct 13, 2015 07:38 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
BLK87Z
Sep 18, 2015 11:29 PM
Mdenz3
Sep 17, 2015 08:36 AM
