No rear sway bar?
Old Aug 2, 2003 | 08:16 AM
F585's Avatar
No rear sway bar?
Why does my 89 Camaro have a rear sway bar and my 85 Camaro doesn't?
Old Aug 2, 2003 | 10:58 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
85 should have one.
BTW, I have some 1991 FE1 swaybars on ebay for sale. End sunday REALLY CHEAP too.
http://cgi6.ebay.com/ebaymotors/ws/e...downndirty_s10
Found my swaybar chart
1985 F41 suspension, should have a 18mm rear, 30mm front.
My 1991 FE1's are 32mm front, 18mm rear.
Old Aug 2, 2003 | 11:51 AM
Y2KFirehawk's Avatar
Car: 00 T/A Firehawk
Engine: 346ci LS1
Transmission: MN6
Axle/Gears: 3.42 LSD
Dale, about those sway bars... are those the same as the IROC sway bars and such? I never heard of FE1 or F41. Thanks!
Old Aug 2, 2003 | 12:17 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
Rear swaybar was an option. My Firebord has it, Y99, Ralley Suspension
Old Aug 2, 2003 | 02:03 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Yep, option. My 82 dident have one either wasent even drilled for one evne though the knockout holes were present. Has one now.
Old Aug 2, 2003 | 04:56 PM
F585's Avatar
Thanks, I was worried for a sec. I heard 36mm up front with 24mm in the rear is the best?
Old Aug 2, 2003 | 05:29 PM
AGood2.8's Avatar
Car: '87 Chev
Engine: 60*V6
Transmission: DY T700
All depends what your setup is (other components, and weight bias) I run 34mm solid front and 25mm solid rear on my V6. Front springs are 800lbs(stock is somewhere near 500) rear springs are 225lbs.
Old Aug 2, 2003 | 07:05 PM
Dale's Avatar
Engine: 350 S-TPI
I installed 34mm front, and 24mm rear on stock springs. IMO, back is just a smidgen to powerful. But I like
FE1 was weekest set for 91
You have different suspension codes. Includes swaybar sizes, and coil spring stiffness and height.
Old Aug 3, 2003 | 01:33 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Get the biggest factory ones you can for the front & rear and you'll be set. Hell you'll notice a difference just by putting any 'ol bar on, not just a big bar. And any trans am or z28 (any year) will have a larger rear bar then stock v6/v8 bars... the rear bar off that '84 trans am 3.73/posi/disc axle of mine is a 23mm bar.
Old Aug 4, 2003 | 11:07 PM
bes217's Avatar
I have a 24 mm rear bar for my car but it does not have a rear sway bar currently. What do I have to do so that I can mount a rear sway bar? Help please!!!
Old Aug 5, 2003 | 08:18 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
All you need from a junkyard is the side brackets (inside the wheel well) for the end links, and the brackets that mount the bar to the axle. They look like regular exhaust clamps but they're not; the flat part is "notched" to fit the axle. There are two pieces of metal, one on each side of the axle, that are welded to the tube. These pieces help locate, and keep from spinning, the mounting bushings.
Then just get new end links from Summit and new greasable (or not) "universal" mounting bushings. I've given part #'s before, just do a search, or look them up at http://www.energysuspension.com 's "Application Guide", in the lower left corner of their menu.
And if you have a Firebird just go under "Camaro" on that website, same stuff. Then either call Summit Racing at 800-230-3030 and ask for a stock/price check, or look it up at http://www.summitracing.com .
Old Aug 5, 2003 | 09:27 AM
bes217's Avatar
I have the bushings and endlinks that I bought from spohn so I was just wondering what else I needed to do to mount the sway bar. Thanks for the help Tom.
Old Aug 5, 2003 | 09:33 AM
Engine: 5.7 / 7.4
the center support brackets & bushings. Also some hardware.
Old Aug 5, 2003 | 07:14 PM
bes217's Avatar
Can anyone give me any pictures of the parts that I need so that I will know for sure what to get, and/or part numbers of what I need from GM or something. What I have so far is the sway bar and Spohn part #PolyRearSB-24-F which is:24 mm rear sway bar bushings and end links. What else do I need?
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Warlocksirix
Sep 3, 2015 12:26 PM
ProtoMaster22
Aug 26, 2015 07:50 AM
