is the 3.4 "U" Intake better than the 3rd Gen design?
Old Aug 4, 2003 | 06:49 PM
Lee7's Avatar
Car: 88 BMW 535i
Engine: 3.5L M30
Transmission: 4HP22E
just wondering.
Old Aug 4, 2003 | 07:20 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
I don't like the 3.4 intake but I do like the 6 pack of coils that usually sits there. There is alot of waste in the cap n rotor system.
Matt
Old Aug 4, 2003 | 07:23 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Only advantage I see is that you dont have to keep taking the upper intake apart to change fuel injectors.
Old Aug 4, 2003 | 09:05 PM
socialdeviant's Avatar
I can see an advantage, as it should keep velocity better, Vs the stock "open box"
Old Aug 5, 2003 | 09:23 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
yeah, shorter runner legnth.
Old Aug 5, 2003 | 03:28 PM
LT1guy's Avatar
Car: 1987 Trans Am
As is, I'm not sure which is better, but I doubt there's any real performance difference. Its a little easier to diasassemble, with less chance of a vaccum leak, but you cant take it apart to port it either, like you can a 2.8 intake. I like the looks of the 2.8 "Klingon" intake better myself!
Old Aug 5, 2003 | 03:45 PM
Lee7's Avatar
Car: 88 BMW 535i
Engine: 3.5L M30
hehe, yeah. It would be really hard to port the 3.4 intake setup, while the 2.8 setup is fairly easy with a Dremel Flexshaft.
The 2.8 setup also looks cool.
Old Aug 8, 2003 | 02:21 AM
Dante93GTZ's Avatar
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
3.4 Intake manifold can be made to work on a 2.8/3.1
Here's a '91 Z24. Granted its a FWD setup, but he's still using the same basic 3.1 setup the RWD would.
Running iron heads as opposed to the FWD's aluminum.
http://turboz24.com/Pics/Current_Engine_29.JPG
http://www.turboz24.com
Old Aug 8, 2003 | 09:11 AM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
well we'd have to get the one off the camaro, also noticed he had coil packs. but, with us running ole' iron heads swaping to that intake puts at the firewall once again, the 3.4L camar owould have to do...but i doubt we'd see any noticeable performance gains from the swap anyway. but, only trying it out would ever tell.
Old Aug 8, 2003 | 09:37 AM
Engine: 5.7 / 7.4
Where's the egr on that sucker?
When I did the swap, I already placed the 3.4 upper on the car. The thottle cable & TV will need to be modified to fit, the top nub on the 3.4 tb opening needs to be ground to let the 2.8/3.1 tb fit. Also, you will need use the 3.4 egr, as the tube is made for the short legnth.
THis egr, though is digital, so doing ait to a 2.8 will be difficult~impossible unless you rewire it to 3.1 specs.
1992rs/ss
Jan 31, 2025 05:10 PM
Fast355
Dec 2, 2016 06:33 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
reiderz iroc
Aug 13, 2015 04:57 PM
