Balancer installation
Old Aug 23, 2003 | 09:16 PM
Damien00677's Avatar
Car: 2006 'Nox 91 Camaro RS 91 1500 Silv
Engine: GM 3.8L, 305 SBC, 350 SBC
Transmission: Auto, auto, auto
How far on is it supposed to be, with my '85 engine, i have the oil pan with the 2 bolts in front and the lip that sticks out. I don't want it touching, but I'll have problems if it isn't on far enough right?
Also is there a good way to stop the engine from turning and get the proper amount of torque on the bolt?
Old Aug 24, 2003 | 05:15 AM
KED85's Avatar
How I've done mine twice.
Go get a balancer repair sleeve, for four dollars from parts store. Use it.
Start balancer on the snout. Tap on with hammer (TAP!), insert the bolt, tighten until no more bolt movement, tap more on balancer, tighten bolt, repeat until the bolt for balancer no longer turns.
Should be using Red RTV on bolt for making sure bolt doesn't back out.
Old Aug 24, 2003 | 01:43 PM
KJay's Avatar
In order to torque those bolts on without rotating the engine over, go to the hardware store and buy a few feet of synthetic rope that is small enough of a diameter to easily slide into a spark plug hole.
Rotate the crank until the piston is at bottom dead center and insert the rope into the hole until full.
Then crank the bolt in the desired direction until it is properly torqued. The rope wont let the piston compress.
Then simply rotate it slightly the other direction and pull the rope out...
Works for me...
Jay
Old Aug 25, 2003 | 09:26 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Be aware that if you use the crankshaft's center bolt to install the balancer, you could snap the bolt and ruin the threads in the snout of the crankshaft.
That's how I broke my center bolt; minus the hammer tappings.
So just be careful.
Old Aug 25, 2003 | 09:52 PM
KED85's Avatar
Tom,
Your experience is why I said "TAP!" the balancer (a solid rap at top & then bottom) & tighten the bolt at the same time.
THOUGH IT CAN BE DONE, I don't feel it is wise to install a balancer by using JUST the balancer bolt
Old Aug 26, 2003 | 08:43 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Tapping at the extreme top and bottom of the balancer can also destroy the balancer if the rubber inertia ring between the center hub and outer ring is damaged... I'm not arguing, just giving warnings,that's all.
Old Aug 26, 2003 | 09:50 AM
Thanks guys, the tapping and hammering worked best for me since I was unable to find a threaded rod since I had already screwed up my threads, when I pulled the crankshaft timing sprocket, and had retapped them already.
Old Aug 26, 2003 | 05:00 PM
KED85's Avatar
Very True!
I also figure that you'd know your balancer is history when it's in your hands.
When the balancer is in your hands you can easily determine if a hammer tap will secure it on the crank or it should become a 12 Gauge ShotGun flying target!
One cannot save an old balancer when the rubber is sticking out of it.
IF your 2.8 balancer is bad, I know of a new, used one available!
italiano67
Dec 11, 2016 09:21 AM
LT1Formula
Nov 16, 2015 01:13 PM
Linson
Aug 31, 2015 04:52 PM
InfinityShade
Aug 22, 2015 08:00 PM
theshackle
Aug 22, 2015 06:52 PM
