Underbody rust - repair
Old Aug 27, 2003 | 06:42 PM
mrzud's Avatar
My project car unfortunately has a bunch of underbody rust. How would I go about fixing this? Should I cut out underbody pieces from another 3rd gen and weld that to my car or would you recommend just sheet metal? If yes to the latter, what type?
What type of welder would I need?
Tips?
Old Aug 27, 2003 | 07:11 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I've done a bunch of welding posts before, use the <a href="search.php?s="><img src="images/top_search.gif" alt="Search" border="0"></a> button, search for "welding" by "TomP" in the "V6 forum" , and you can also search the "Body & Interior" forum. You'll find info on welders in those messages.
As to replacing that rust, I'd say just use regular sheet metal. Nobody's gonna go looking under your car to see if your original floorboards are there! And if they do look, they're too damn close, and they'd better get the hell away from the car because they're up to no good!
You can buy sheet metal at Home Depot in the hardware aisle. Make sure you buy steel and not aluminum. They sell some zinc-coated steel, but the zinc can give off poisonous gas when it's heated up by a welder, so either work in a very well ventilated area, or remove the zinc from the weld areas with a grinder.
Oh, what the hell, I'll do one search for you. Not too much info in this post... maybe try choosing the body/interior forum for your search. Here's what I wrote in message https://www.thirdgen.org/techbb2/sho...hreadid=137354 :
Originally posted by TomP
Well to replace rear panels, you're going to need to weld. You can go for a fullblown MIG system, which costs a bit to get yourself started, or check out http://www.eastwoodcompany.com for their complete Firepower arc welding kit. Normally, arc welding is too powerful to do work on the thin body sheetmetal of a car, but the kit comes with two adapters to allow low-amperage work. Here's a link: http://www.eastwoodcompany.com/itemdy00.asp?T1=19266
I have a MIG setup.. the Lincoln Electric Weld-Pak 100 ($300), the gas conversion kit ($100), and a 40 cu/ft argon/co2 bottle ($100, $15 to fill with gas). Recently I added a $170 auto-dimming helmet to my tool list. (I recommend it!!! Makes welding much more precise!!!) So that's comparing $515 to $200 ... I wanted the first welder I bought to be my last. But if you're just going to do panel replacement, and then not weld for a while, this kit might be the way to go.
Eastwood also sells a no-weld panel replacement system, using a rivet gun, a flush-rivet tool, and special adhesive caulk, but it's mainly meant for small patch jobs, not replacing large (and structurally important) panels.
Hop to the "body & interior" board, and do a Search for "quarter panel" written by "TomP". You'll see my messages of what I'm planning to do, and see the picture of the 1/2 of Firebird that's in my backyard, waiting for me to weld it on.
Go on eastwoodcompany.com and go under their body and fender link, then under patch panel repair, and on the second page you'll see the no weld panel repair kit, number 31102.
Old Aug 28, 2003 | 07:27 AM
mrzud's Avatar
Thanks. I would have done a search myself first, but I was on a real slow connection (21kbps) barely got the post through, hehee.
Old Aug 28, 2003 | 09:51 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
https://www.thirdgen.org/techbb2/sho...hreadid=189093
https://www.thirdgen.org/techbb2/sho...hreadid=192017
Old Aug 29, 2003 | 07:40 AM
mrzud's Avatar
thanks!
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
SRKLEGIN
Sep 30, 2015 07:19 PM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
ironbmt
Sep 27, 2015 06:00 AM
