Maximum V6 power
Old Sep 14, 2003 | 09:31 PM
StreetRoc85 350's Avatar
Car: 88 IROC
Transmission: Pro 5.0 shifted T56
Axle/Gears: 10 bolt 3.73 posi
Maximum V6 power
well the cam just went out in the 'bird and with 150k on the clock, its time for a rebuild. my question is, where can i go to get v6 parts? i mean like high comp pistons, cams, etc. i cant do a small block swap because my dad is paying for this, i just want a little more ***** from my midget motor. i did a search but i got nothing.
any ideas
Old Sep 14, 2003 | 10:16 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
3 POINT 4
Old Sep 15, 2003 | 12:02 AM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
I agree, go with a 3.4L motor. Buying all the stuff that you want (high comp. pistons, cam, heads, headers) will cost you about the same as doing a small block. If you want something cheap and easy, do the 3.4L.
Old Sep 15, 2003 | 12:25 AM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Nitrous
Custom Turbo
3.4
Quickest/best ways to get power quick from the little engine!
Old Sep 15, 2003 | 12:35 AM
Car: 1988 Camaro RS
Axle/Gears: 3.42's
mmmm...3.4 Turbo ...with nitrous Would be a pain in the *** to tune though. i don't even know if that's possible. Well, I take that back, anything is possible, given enough time and money, but possible and affordable...no way!!!
Old Sep 15, 2003 | 12:43 AM
Engine: 5.7 / 7.4
yes, possible. turbo w/o intercooler, spray to cool charge (sneaky pete), or even water injection.
Old Sep 15, 2003 | 01:25 AM
Really-Slow-RS's Avatar
ARI Racing Engines in Grandview Missouri has cams, pistons, heads, and even a stroker kit for around $500. www.engine-parts.com is the web site, they should be able to give your six banger some more *****. Also other things are available like MSD Ignition, gears, tranny build-up, light weight components (flywheel, drive shaft, etc.), computer chip (Ed Wright at www.fastchip.com burns a mean chip), there's hundreds of things that will make your car faster (but I don't recommend nitrous).
Old Sep 15, 2003 | 01:54 AM
omarbreadbeek's Avatar
ed wont burn any chips if u have bigger injectors he said he hasnt messed with the fuel tables and flow constants....
Old Sep 15, 2003 | 03:09 AM
Doward's Avatar
Jesus.. then what's even the point of a new chip??
Anywho...
Old Sep 15, 2003 | 04:32 AM
you will have to go through kc speed.... although other companys might be able to do it... but ireally takes time not just a guess, on what u need....
Old Sep 15, 2003 | 11:10 AM
Car: 88 IROC
well i would go with a 3,4 but like i say, my dad is paying for this and he wants to keep the stock 3.1 block. thats why im pretty much limited to pistons, cam and head work. by the way, how big of a pair of valves and i stuff into those chambers on the v6 heads? maybe some borrowed 350 valves would work? ideas???
also kinda off topic, but who do you think has the baddest v6 on TGO? a few people ive seen with 3.4 turbos....
Old Sep 15, 2003 | 11:37 AM
Car: 1988 Camaro RS
Axle/Gears: 3.42's
th block on the two motors is exactly the same. After you put in the 3.4 block and heads, all of the intake and exhaust components that you have mow will just pop right on. It's definitly the way to go unless you have a sentimental attachment to the motor that's in there right now.
Old Sep 15, 2003 | 12:53 PM
Doward's Avatar
Baddest 6 on TGO?
Don't know... I think my '88 should get racked up there (Only turbo 6 on these boards)
There's also a couple guys running 75 shots on 3.1s... probably faster than me (gotta nail 8 psi)
Not sure... who's fastest on here? Wednesday I'll have new times...
Old Sep 15, 2003 | 02:57 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Originally posted by Doward
Baddest 6 on TGO?
You ever seen that guy who run his stock 4 cylinder van at like 21 psi boost with 6 fuel injectors???
Id have to look for it but anyways he just rigged up extra injectors in the TB hose for more fuel when needed.
Old Sep 15, 2003 | 04:29 PM
The_Raven's Avatar
Car: 1985 GMC Jimmy/1998 Chevy Malibu
Engine: 3.2L turbo Hybrid/bone stock 3100
Transmission: T-5 soon to be 700R4/4T40E
Baddest 6 on TGO?
Only turbo 6 in a 3rd gen, but I also have a turbo V6, it's just in my Jimmy.
Old Sep 16, 2003 | 07:35 AM
Brian K's Avatar
Ya if it is time for a new motor get a 3.4 and have the following done to it:
1. Pace Setter Headers for the 3.4
2. Forged pistons so you can spray a 75-90 shot of nitrous
Enjoy a 14 second to high 14 second 1/4 after that..
Old Sep 16, 2003 | 07:27 PM
Car: 1988 Camaro RS
Axle/Gears: 3.42's
the pacesetter headers will not fit in our cars. They angle too far back and hit the firewall. We are actually working on getting pacesetter to make a set designed to fit in our engine bay's though. They will fit any 2.8/3.1/3.4L motor I think.
Old Sep 16, 2003 | 08:17 PM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
if you rebuild that engine, or do a 3.4L swap, use the forged internals and run waaaay more than a 75-90 hp shot, since a stock motor should hold 100 w/o a proble, run that 150 shot, run low-mid 14's put some gears in , get great gas millage (lol, we don't get that) and stomp a lot of stock rides. best of both worlds i guess,
Old Sep 18, 2003 | 05:48 PM
614Streets's Avatar
If I were in your shoes I would hurry up and buy oversize l249f trw forged pistons for the 2.8 , overbore it, add a crane 272 cam from paw, have the heads rebuilt , find a decent set of headers. You have to hurry on the l249f's they were just discontinued by trw/ speed pro and I know I got the last set from PAW, Parts america may still have a couple sets , check online. And run just a 100 shot , no more. Paw still carries a good moly ring set for the 2.8 , speed pro has discontinued their ductile plasma moly ring set (file fit) and total seal wants big bucks for a set made of ductile iron. Stick with the 2.8. This is a low low cost option that will out run a 3.4 dollor per dollor , the 3.4 pistons dont like nitrous nor do the 3.1 pistons.
Old Sep 18, 2003 | 10:17 PM
Doward's Avatar
The 3.4's maybe... but the 3.1s? They're just 2.8 pistons with a different rod pin offset. You can pick them up in hypers, or forged.
Old Sep 19, 2003 | 12:51 PM
614Streets's Avatar
Actually the 3.1 are the weakest pistons of them all, they have a dish top with a very thing area between the top ring land and the edge of the piston dish. Very easy to blow out at that intersection. The 3.4 are stronger but have a thin deck. The 2.8 slugs are by far the strongest. And by forgings , the l249f can be had for $250 and under , whereas the 3.1 and 3.4 forgings are a custom job.
Old Sep 21, 2003 | 11:29 AM
asylist's Avatar
Prolly thinking of the late Gus Mahon (wonderful guy, taken too soon...). That van was a bit far from stock, but still bad ***. 91 Caravan if I remember correctly, and aside from the slicks it looked bone stock from the outside. Also had a 12.25 second K car. There's an awesome video floating around on the internet somewhere of him slaughtering a Supra. In the back ground you can hear people heckling him at the staring line for pulling up in a K car. Its hilarious.
Old Sep 21, 2003 | 01:35 PM
Lee7's Avatar
Car: 88 BMW 535i
Engine: 3.5L M30
Transmission: 4HP22E
haha, yeah i saw that K-Car video, it was funny. IIRC he got it into the 10's in a different video.
edit: found the site, http://www.thedodgegarage.com/the_reliant.html
heres the one where he spanks the supra: http://www.thedodgegarage.com/video/...supra_long.zip
Old Sep 24, 2003 | 10:08 PM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
Ahem, I have a turbo 6
Old Sep 24, 2003 | 10:29 PM
Doward's Avatar
Ahh... you don't count. You're not a 60 degree!! But then.. he didn't specify.
What are you running, fly? 1/4 mile wise... wondering what it woudl take to catch you... probably more than a 10psi 16g.
Old Sep 25, 2003 | 05:41 AM
fly89gta's Avatar
Car: 2018 Camaro SS
not sure yet, had problems with the motor before I could run it the first time it was in
Going for high 11's/low 12's on pump gas,after that mid 11's on alchy. I have the turbo to do it, just gotta get everything else set up
Mr. Chevy
Sep 11, 2015 06:06 PM
onebad82z
Carburetors
Oct 12, 2004 08:08 AM
chris718
Aug 29, 2004 08:54 AM
wjbecker
Mar 13, 2004 06:21 PM
TP355Z
May 5, 2003 08:38 PM
