timing
Old Sep 16, 2003 | 10:16 AM
paintshooter's Avatar
timing
I need to set my timing and what is good for the 2.8 85 camaro. Did a search and really didn't find anything. Is top dead center good or should I back it off?
Old Sep 21, 2003 | 09:25 AM
coolrimsatleast's Avatar
Car: 89 f-bird and some others
Engine: 3.4
mine is 10degrees, but it's an 89 EFI 2.8 not sure if yours would be the same
Old Sep 21, 2003 | 03:25 PM
camaro_junkie's Avatar
Car: '86 Camaro SC, '16 QX60
Engine: 2.8 V6 POWER, 3.5L V6 N/A
Transmission: T-5, CVT
I've got an '86 and spec is 10°. I usually advance it 2° to 12°BTDC, but right now I'm having timing issues.
Old Sep 22, 2003 | 12:22 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Your car wont run at 0 degrees of advance. As they said, 10 degrees of advance is stock. 12 degrees is good for some extra pep, although the car might run funny on 87 octane, depending. 89 would work good for that though.
Old Sep 24, 2003 | 08:48 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Ha. Mine only runs at 0 deg TDC, but I guess that newer ECM should help fix that, and the running super lean, and the fact that the engine only runs with the MAF disconnected, and maybe that Code 54 that's been bugging me too....
Old Sep 24, 2003 | 09:29 PM
If your car only runs at 0°, then either your engine is seriously messed, or there's something wrong with your timing marks.
Old Sep 24, 2003 | 09:32 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Like I said, the ECM is junked. I'm searching for a newer one on eBay right now... plus, I'll have to check the marks too when I get the time and money, I ain't sure they are right, but that's what it said when I made the rotor marks with the #1 terminal when I removed the distributor, so that's anyone's guess...
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
