spark plugs
Old Oct 21, 2003 | 10:28 PM
PILU's Avatar
Car: Firebird 89' and Formula 87
Engine: 2.8 l and 350 v8
Transmission: 2.8 Manual 5 speed and 5.7 manual 5 speed
spark plugs
I what do u think in putting those bosh spark plug with 4 points that cost like 6 bucks each, sorry I don't know howare those sparg plugs called.
would it game me some more HP?
Old Oct 21, 2003 | 10:29 PM
PILU's Avatar
wops sorry about the bad english, not first lenguage
Old Oct 21, 2003 | 10:54 PM
PILU's Avatar
wops i found the info, i should search more instead of asking lol
Old Oct 22, 2003 | 10:35 AM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
Yeah the search feature definitely helps out, I've found quite a bit of info on what I've had to look for before by running a search.
One more thing bud, instead of adding a new post if you find something or forgot to add something, just click the "edit" button which will allow you to modify your existing post. I don't think it's worth the $6 a plug for the bosch platinum +4 plugs. Invest in some AC delco plugs, you are probably better off.
Old Oct 22, 2003 | 11:22 AM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Yep, good ol' AC Delcos are the way to go.
Old Oct 22, 2003 | 04:29 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Autolites are very good plugs as well...
Those Bosch +4's are a rip off. Completely unnecessary. Someone else mentioned, however, that the +2's are nice for just the reason that they have a good, direct escape path for the spark since the direct center of the plug isn't covered by 1 large electrode, rather centered between 2 smaller electrodes.
While we're on the topic of ignition also....don't buy the Splitfire plugwires either. I almost fell out of my chair laughing when I read those ads.
Old Oct 22, 2003 | 08:45 PM
DJsyclone's Avatar
I had some money burning a hole in my pocket, that's why I got the Bosch Platinum +4. Not sure that they make a difference but they are some good looking plugs and they don't have to be gapped.
Old Oct 22, 2003 | 10:09 PM
AGood2.8's Avatar
Car: '87 Chev
Engine: 60*V6
Transmission: DY T700
The only reason those plugs feel good to most people at first is because they don't need indexing- there really is no way you can. But they are still shaded from the valves slightly, AND have four obsturctions to the charge instead of one. Use Autolites (regular A/C Declos are bad- but rapid fires burn up as quick as Bosch +4's. Just look at the tiny electrode. And Most of all- index the plugs. It takes time, but will give you better power no matter what plug you run.
Old Oct 23, 2003 | 12:31 AM
PILU's Avatar
allright yhanks for the info.
I'll try the autolites, i guess those arew sheep.
Old Oct 29, 2003 | 07:24 AM
The "gimmicks" always crack me up, but I've never seen an ad for a splitfire wire. What do they claim?
Old Oct 29, 2003 | 08:55 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
accel plugs are great, they last forever and I have never had a set or 1 foul.
Wish I could getthem for my bike. I can foul a NGK is seconds.
Matt
Old Oct 29, 2003 | 02:20 PM
Nixon1's Avatar
The Splitfire wires, if I remember right, claim better spark energy due to their 'dual conductive paths'. The wires are 2 conductive cores twisted around eachother.
Old Oct 29, 2003 | 03:44 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Too bad electricity always takes the shortest path!
That's why people thought the splitfire plugs were junk; they thought the spark "split" into two. Uh-uh... no way; Splitfire never even claimed that for the plugs. They claimed less shrouding of the spark, due to the opening in the split-electrode. Sort of like the effect that a cut plug would generate, without the longevity issue.
Old Oct 30, 2003 | 11:42 AM
Nixon1's Avatar
From a Splitfire plugwire ad in Summit:
"In tests, Splitfire's Dual Mag Wire showed 92% lower resistance than stock carbon core wires. Splitfire uses two wires instead of a single, equivalent-sized wire, greatly reducing resistance and getting more power to your plugs."
Old Oct 30, 2003 | 12:28 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
What is the price on them suckers???
Old Oct 31, 2003 | 04:47 PM
Nixon1's Avatar
$59.99 for most V8's.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
Jlanz55
Sep 9, 2015 09:09 AM
90formulaVortec
Sep 8, 2015 12:42 AM
89 formula TPI
Sep 7, 2015 11:06 AM
