please help, msd 6a, don't argue
Old Nov 14, 2003 | 11:06 AM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
i'm assuming that is why the other thread got locked but i do need a little help. here is a picture of the way i spliced the wires (as far as i can tell, just like msd tells you to) but i must be missing something.
Old Nov 14, 2003 | 11:29 AM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Couldn't tell you... there should be a tach reference signal (on my '77 'bird, it was the ground side of the coil, I believe) that you should hook up. It IS the tach that's giving you a problem, right?
Old Nov 14, 2003 | 12:47 PM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
Post deleted since upon further inspection, the picture is just too bad to tell.. better picture neccessary.
Old Nov 14, 2003 | 12:53 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
this help?
Old Nov 14, 2003 | 02:01 PM
TechSmurf's Avatar
Engine: LS1, Scrap
well, glancing at this and glancing at my haynes manual, the white wire on the gray plug *used* to be your tach lead.. hence its disfunction.. MSD's diagram doesn't seem to have any provision for this...
I'd try running a jumper between the white 6A output wire and the white wire that used to go to the gray connector... but that's just what I'd try. Never hooked up an aftermarket ignition box..
And Mr_Dude, thanks for having more motivation to do a quick photoshop on the image than I did.. never ceases to amaze me how much information a jpeg can contain
Old Nov 14, 2003 | 04:05 PM
Car: 91 Camaro
i can try jumping that wire that you mentioned techsmurf but i did already try unhooking it (to see if it was just a tach lead) and it killed the motor must be a ground too or something.
Old Nov 14, 2003 | 08:48 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
My setup:
http://images.cardomain.com/member_i...42_15_full.jpg
http://images.cardomain.com/member_i...42_16_full.jpg
http://images.cardomain.com/member_i...42_17_full.jpg
http://images.cardomain.com/member_i...42_18_full.jpg
TechSmurf's Avatar
Engine: LS1, Scrap
I think your distributor is relying on that ground, now.. however, I think you need to tee it off to the white wire that used to run to the gray connector.. not sure if the tee would be good enough though.
At any rate.. I'm pretty sure that poor abandoned cut white wire is your old tach lead.. that should help you out by leaps and bounds.
Old Nov 14, 2003 | 11:17 PM
Car: 91 Camaro
thanks for the pictures, maybe i can figure it now.
side note: i just got back from a little "car show", boy did the little v6 surprise some people! the supercharged R/T's 33 ft tire tracks didn't look as empressive as they did before i did it too.
Old Nov 14, 2003 | 11:35 PM
Engine: 5.7 / 7.4
TechSmurf is correct, the white lead is for the tach.
How 'bot some pics of said burnouts
Old Nov 14, 2003 | 11:52 PM
Car: 91 Camaro
unfortunately my tires don't make much smoke but they need replced so i'll see if i can get some burnout pics before i change them.
edit: if you're not believing me, ask Doward, he's riding in it. if you just want to see some pics, i'll try to get some at some point...don't know exactly when it'll be though.
Old Nov 15, 2003 | 12:36 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Swet dude
Thats a way to show em. Sounds like the MSD is working out.
Matt
codeysabatini
Nov 10, 2015 04:07 PM
sreZ28
Oct 22, 2015 08:21 AM
RedLeader289
Sep 23, 2015 06:50 AM
TexasMaro
Sep 15, 2015 06:50 PM
GH6801
Feb 27, 2001 02:34 PM
