Anyone else suffer from this?
Old Nov 22, 2003 | 04:38 PM
Teenfixing88RS's Avatar
Car: 1988 Camaro RS
Well... i have a 2.8L V6 MPFI 5 speed... well there are times when my car begins to stumbble.. let me be more specific
The RPM drop to about 500 when im at a stop light and the car feels like its about to shut off.. and if i dont hit the accelerator the "service engine soon" light comes on... But wait.. then there are times when my car revs itself up to about 2000 RPM for no reason when im coming to a stop... Any ideas what it might be?
Old Nov 22, 2003 | 05:43 PM
87CamaroMan's Avatar
Car: Chevy Cobalt & Camaro
Engine: 2.2 DOHC/3.1
Transmission: Not so slushy slush box/Slush Box
Axle/Gears: Stock 3.23
Timing. Vacume leaks, Fuel blockedge (new Fuel filter), Fuel, pump.... It could be alot of things... My car used to do that. I just readjusted my timing and change my cap and rotor.. and it stopped
Old Nov 22, 2003 | 06:55 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
Idle Control Motor. Does it only happen when you are comming to a stop? That would be my guess since you have a stick and anytime you disengage teh clutch with no throttle it want s to go to idle and that's where you are having the problem. TomP tune-up time it is!!!
Old Nov 22, 2003 | 07:18 PM
Lee7's Avatar
Car: 88 BMW 535i
Engine: 3.5L M30
Transmission: 4HP22E
either the IAC or timing. Moe's car was doing this when we put the timing at 14 degrees (from 6!) So we put the timing back some, and it was still doing it. We then changed the IAC and it was fine.
Old Nov 22, 2003 | 09:10 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
IAC is usually what causes this. When was the last time you cleaned the throttle body out. A carbend up TB can do it to, any idea what code your getting? If it somthing to do with TPS it can be a dirty TB and the car will idle up and down in an attempt to self clean.
Old Nov 22, 2003 | 11:25 PM
Car: 1988 Camaro RS
IAC?? thats a new one for me.... thats true its been a while since i cleaned it
Infested
May 22, 2018 11:56 PM
ULTM8Z
Sep 16, 2015 09:15 AM
86White_T/A305
Aug 17, 2015 12:16 AM
zedder 1 9 9 0
Dec 11, 2001 10:34 PM
Cakes12
Nov 17, 2001 10:50 PM
