Cold Start Injector Question...
Old Dec 2, 2003 | 04:15 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Where does the CSI get the air from? I know it's the tube there right next to it, but where did that run to? I capped it off, but I'd like to know where it should have gone...
Old Dec 2, 2003 | 05:38 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
The Cold Start Injector is for fuel...not air, so i don't think that it gets air. The tubes right next to it are for the PCV system I think.
Old Dec 2, 2003 | 06:04 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
yeah, the place where it shoots the fuel is an open area in the base manifold.
Old Dec 2, 2003 | 09:10 PM
Doward's Avatar
I popped my csi out today (part of the 3.1 build/swap) and noticed that the tube there next to the injector goes right into the passage that the injector shoots the fuel.
Is that part of the PCV system?
Anyone have a diagram of the PCV system? I really should have paid better attention before just yanking all those tubes out
Old Dec 2, 2003 | 09:27 PM
Engine: 5.7 / 7.4
for the 85 cars:
Old Dec 2, 2003 | 09:55 PM
Doward's Avatar
Any chance you've got a bigger pic of that you can email me?
Doward_@hotmail.com
I can't see anything in that one
Old Dec 2, 2003 | 10:01 PM
Engine: 5.7 / 7.4
I'll take a better one, that was when I still had teh bra on & 3.4 open manifolds was running seamlessly
Old Dec 2, 2003 | 10:13 PM
Engine: 5.7 / 7.4
ygm
Old Dec 2, 2003 | 10:41 PM
Doward's Avatar
Ok, so the tube (the one labeled 'to manifold inlet' - that should be the tube next to the csi I'm talking about)
Anywho, that tube runs into another tube that has the driver's side PCV valve, and runs to the charcoal canister, as well as to the tube next to the IAC?
Can anyone verify/disprove this?
What i really need, is a pic of the piping in the car. : /
Old Dec 3, 2003 | 12:02 AM
Engine: 5.7 / 7.4
I'm pretty sure teh tube beside teh csi goes either to teh pcv or the brake booster. I didnt really check tonight.
Old Dec 3, 2003 | 06:13 AM
Doward's Avatar
The brake booster hose goes from the booster, straight to the 'T' on the back of the upper plenum.
Anyone have a picture of the PCV system? I found a couple of my old pics, but they only show that the hose from the tube next to the IAC goes down under the upper intake. I really need to see the pipe that comes off the driver's side PCV valve, and see where it goes.
Old Dec 3, 2003 | 06:47 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
My drivers side PVC pipe goes to the back of the very lower intake. Angles out to the drivers side.
This a 3.1l
Old Dec 3, 2003 | 06:56 AM
Doward's Avatar
Wow.. Guess it never occured to me, to LOOK AT MY OWN HOOD.
Cripes I feel like a bleeding idiot.
Of course, I've got an excuse - I had to FIND my hood again
Old Dec 3, 2003 | 02:34 PM
9D1BURD's Avatar
Moderator/TGO Supporter
Car: 1997 Z28
Doward, if you want i can take a pic of my 91 3.1 later tonight. Not sure if everything is the same though.
Let me know.
Tim
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
