I need code 43 help
Old Dec 4, 2003 | 12:12 PM
9D1BURD's Avatar
Moderator/TGO Supporter
Car: 1997 Z28
I need code 43 help
Have any of you had any luck fixing code 43?
I have the some info on how to track what it is, but it always checks out.
Now, under light to hard acceleration the car will hesitate real bad, almost to the point where the RPM's will not even rise.
Old Dec 5, 2003 | 08:08 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: I need code 43 help
It would be either a bad sensor or the wire from the sensor to the ECM is bad. Bad wire includes the connectors.
May also be the MEMCAL as that houses the knock filter. Rare, but it can happen.
The $88 mask doesn't have a forced knock test, it only checks the resistance of the sensor and for run-away knock.
Acceleration suffers as when a code 43 is present a set amount of timing is removed.
RBob.
Old Dec 5, 2003 | 09:07 AM
9D1BURD's Avatar
Car: 1997 Z28
Any idea on what the sensor may be?
I have lost my diagrams that i thought i still had, anyone have one?
Old Dec 5, 2003 | 11:24 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
It be a microphone. Low on passenger side of block, right above oil pan rail. Between starter & motor mount.
RBob.
Old Dec 5, 2003 | 03:51 PM
9D1BURD's Avatar
Car: 1997 Z28
It be a microphone.
I'm confused, my problem could be a microphone?
Old Dec 5, 2003 | 04:06 PM
zoomzoom's Avatar
ESC, electronic spark control- your knock sensor
Old Dec 5, 2003 | 06:11 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
My mistake, I didn't realize that you didn't know that code 43 was an ESC malfunction: the knock control system. So when you asked what he sensor was. . well, it is a microphone (seriously).
Anyway, what zoomzoom says, the ESC system, or knock sensor. Round metal can like thing with a single wire lead to it. Almost round connector, press wider sides of connector to release hooks and pull off.
RBob.
Old Dec 8, 2003 | 10:30 AM
9D1BURD's Avatar
Car: 1997 Z28
LOL, thanks, i knew what code 43 was, i was just not making the connection between the knock sensor and a microphone.
thanks again
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
