Anyone know an easy way to remove the clutch master cylinder?
Old Jan 10, 2004 | 08:51 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Thier is like a plastic nut on the clutch pedal that the master cylinder is attached to and I do not want to break it off and there is not a whole lot of room to work with. Anyone have any tips on this? Thanks.
Old Jan 10, 2004 | 09:18 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
If I remember correctly you just pop it off. Wedge a screwdiver in and pry it.
Old Jan 10, 2004 | 09:21 PM
pasky's Avatar
Will I need a new one when installing another master cylinder?
Old Jan 10, 2004 | 10:26 PM
Engine: LH0 3.1L
The new MC should come with a new plastic retainer.
Old Jan 11, 2004 | 01:08 AM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
Does anyone know where to get these plastic thingies? The one on the new assembly I bought for the swap broke IMMEDIATELY after installing it.. not major.. found a way around it.. but still.
Old Jan 11, 2004 | 01:27 AM
pasky's Avatar
I would like to know also, because my new cylinder is used and I imagine it will not come with it.
Old Jan 11, 2004 | 02:30 AM
TechSmurf's Avatar
Engine: LS1, Scrap
It does.. but as I said.. mine broke like the second time I pressed the clutch in.. and it hadn't even been bled yet.
Old Jan 11, 2004 | 02:46 AM
pasky's Avatar
Well what I meant was, its coming off a 95 trans am used, Im pretty sure they popped it to get it off also, pretty sure im gonna have to look for one of those.
Old Jan 11, 2004 | 02:49 AM
TechSmurf's Avatar
Engine: LS1, Scrap
Oh.. yeah.. time to find a new one or find a way to get around it.
Old Jan 11, 2004 | 02:54 AM
pasky's Avatar
How exactly did you jimmy rig yours? That way if no one does know where to get these I can at least have something to work with, thanks.
Old Jan 12, 2004 | 02:55 AM
TechSmurf's Avatar
Engine: LS1, Scrap
Err... If I recall I zip-tied the pushrod to the pedal.. but I don't reccomend trying this at home. I had the zip tie slip once and the pedal got stuck down, but I haven't tried to pass this car as a daily driver in over 2 years, so I can get away with that kinda thing. I plan on buying a pack of misc-sized C-clips once she's running again and seeing if one fits the groove in the connecting rod.. I'll let you know.
Old Jan 16, 2004 | 03:24 AM
pasky's Avatar
Ever find a C-Clip that will work? Thanks.
Old Jan 16, 2004 | 04:06 AM
TechSmurf's Avatar
Engine: LS1, Scrap
Too busy getting the kinks worked out of the turbo.. it could be a while before I get around to caring about the clutch..
Old Jan 17, 2004 | 04:45 PM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
you can get them fom thedealership, like four bucks, when my clutch would not work that was the problem, i had mine break in rush hour trafic, had to wrestle it out of gear no to hit somebody. they are megga hard to install, i almost broke mine too. if you want a c-clip get the one for the break pedal, seems like it should be same size.
Old Jun 13, 2004 | 10:36 PM
jumpingjakflash's Avatar
Car: 83z28; 84 z28 H.O.
Engine: 350 bored .060 xe268 cam 10.5:1 comp
Transmission: WC T-5
Yea I had to do that, it works just fine but leave the borken white clip on there also so the pedal doesnt have freeplay with the rod. The rod slips over part of the white clip, then place a clip like the brake pedal clip on there and u should be good
hope that makes sense
25thannivZ28
Aftermarket Product Review
Jan 2, 2016 05:41 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
87 camaro iroc
Aug 20, 2015 07:47 AM
redmaroz
Aug 16, 2015 11:40 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
