2.8 -> 3.8
Old Jan 11, 2004 | 08:07 PM
projektz_born's Avatar
Car: 99 Z-28 87 2.8
Transmission: all manuals
2.8 -> 3.8
well i found an 2001 firbird engine complete with trans and all accessories but in looking at all the topics everyones swapping 3.4s not 3.8 is there going to be any difference?? i got an 87 2.8 5 speed. just looking for imput.
Old Jan 11, 2004 | 08:25 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
yes, we have a current member trying this, major different things.
wheres project85, this is one he needs to respond to.
Old Jan 11, 2004 | 08:46 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
What I've done to make this swap happen:
Pull out entire 2.8 harness, including ecm.
Rewire dash to accept 88 cluster & the full VSS things
Swap out 700-4R & 3.4 to be replaced by the 4L60E & 3800
Still need to do:
-Fab up motor mount brackets (I have an idea on how to reuse the 2.8 mounts)
-Reconnect fuel feed & return lines
-Waiting on someone to move & get address to get "new" 4th gen evap can
-"Make" radiator hoses that will fit
-Relocate battery to pass side (batt cables on harness are for that side)
-See if my rebent tranny lines will work, or if I cain use the 4l60E lines (they might not match up due to differences in engine bays)
-VATS/PASS-KEY (already have a lead on that)
probably some more little stuff that will come up, that those are the biggies for now.
Old Jan 12, 2004 | 06:44 PM
Car: 99 Z-28 87 2.8
would you think it would be easier to just go to an lt1? i am going to be getting rid of my 99 Z28 and keeping the 87( cant get rid of it love it to much) and i wanted to do an engine upgrade. but it appears the 3.4 will be easier i really wanted to get this swap done in about 3 days. so any good ideas where i can get a 3.4?
Old Jan 12, 2004 | 08:09 PM
Engine: 5.7 / 7.4
Depends on how much you get w/the swap. Mine was actually a pretty good deal. Also depends on what you're looking for ( I'm a Poncho 400 (or bigger) man myself ). Check out the engine swap forum on info fo rthe LT1 wap, hatian boatloads of info.
As far as the 3.4 donors, 93~95 F-body w/them, or victoms of melted/fudged up engine harnesses w/3.4s in them like myself
86maro_252
Oct 10, 2015 06:52 PM
usafirebird
Sep 29, 2015 11:58 PM
spartanreaper
Sep 25, 2015 07:22 PM
RABMAN
Interior Parts Wanted
Sep 18, 2015 09:02 PM
89bird2.8
Sep 18, 2015 07:46 PM
