3.1 -> 3.4 swap questions
Old Jan 17, 2004 | 02:19 AM
krazycracka55's Avatar
Car: 92 RS 25th Anniversary
Engine: 3.1
ok first of I HAVE USED THE SEARCH BUTTON!!
and have been successful on findint the 2.8 to 3.4 swap by ked85
i was just wondering if the same parts were used of the 3.1 and if anybody that has done this has some pointers for this
im getting a 3.4 for 500 for everything !!
:lala: :lala: :lala: :lala:
Old Jan 17, 2004 | 02:50 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
substitute 2.8 w/3.1
Old Jan 17, 2004 | 03:33 AM
Engine: 3.1
good stuff
Old Jan 17, 2004 | 04:20 AM
Engine: 3.1
what kinda tranny is in a 95 maro? is it the t-5?
i would like to get rid of my auto shift-o-matic 700r4 due to it liking to hold 3rd gear from a punch till a let off the gas then slam it back down
Old Jan 17, 2004 | 05:34 AM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
GACK! No no no! There are differences!
Speed Density vs. Mass Airflow: The 2.8 ECU can compensate readily for the 3.4 with its stock injectors since it directly measures airflow, the 3.1 would be CLUELESS. Lean, lean, and more lean. Using the 3.4 injectors would be a straight *requirement* or you'll burn the motor. In contrast, using 3.4 injectors in the 2.8 swap without rechipping for the injectors is rather silly and will run pig rich in open loop, and BLMs would be insanely low in closed loop
Water pump swap becomes a moot point, all 3.1s used CCW rotating serpentine setup anyway.
Flywheel is moot point. Both are neutral balanced.
Basically, to do the swap correctly, all you need is the 3.4 long block and injectors.
As far as the tranny goes, they use the same transmissions as thirdgens. T5 or 700R4/4L60. Your problem is the 700R4/4L60 refusing to do 3->4 shifts at more than 2/3 throttle. They all do that. If you're looking for shift speed, this is a silly point, since with the T5, now you're letting off the gas for ALL shifts instead of just one. Granted, the T5 is fun to drive.. it's also a big can of worms concerning the swap.
Old Jan 17, 2004 | 10:37 AM
Engine: 3.1
so all i need is the 3.4 injectors, it sounds like your tellling me to just pull the 3.1 out and drop the 3.4 in since the injectors r already intacked
well im getting the 3.4 from a guy a know thats parting out his 95 5spd camaro.... and i was the first to call dibs on the engine/tranny
Old Jan 17, 2004 | 11:11 AM
FbodTrek's Avatar
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
Hold on!
Just a minute Techsmurf, I was told that going 2.8 to 3.4 you had to use the 3.4 injectors?!? The Mass air is going to measure a higher volume of air coming in, the injector pulse witll be lengthened, but I always thought the 16Lb 2.8 injectors couldn't flow enough to support the amount of air coming in (which makes it lean). With the 3.4 injectors, the pulse will be self corrected through the input of the Maf, O2 readings, Tps. Remember, the computer trys to make the car run at the right A/F ratio......
Old Jan 17, 2004 | 11:47 AM
Engine: 5.7 / 7.4
yes, but the 3.1 isn't a MAF engine, that's what TechSmurf is getting at. I never had a problem running lean.
Old Jan 17, 2004 | 11:59 AM
GreyFox's Avatar
Car: 1991 Firebird
Engine: V6
Transmission: ATOD
ok ok so is my 3.1 **** ? should i get a new eng?
Old Jan 17, 2004 | 12:54 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
krazy, its basically the same. Only thing you wont have to worry about is the plug thats required to be removed from the head for the fan sensor. Thats it.
I belive the tranny is still "called" a t5. I'm not 100% sure it will work in our cars, I didnt study that in my searchings.
Old Jan 17, 2004 | 01:35 PM
Engine: 3.1
i was just wondering cuz if i go na tune i would like a 5 spd, but i did find a full aritcle of parts needed to throw a t-25 turbo on a 3.4 (www.camarov6.com) and if i go fi im going to stay with a auto
Old Jan 17, 2004 | 02:40 PM
Engine: 5.7 / 7.4
You're looking at Tiago's kit huh? group purchase price is good.
Yes, the 4th gens had T-5 for the 5speeds, & T-56 for the 6 speeds.
Old Jan 18, 2004 | 03:06 AM
Engine: 3.1
sure did
Old Jan 18, 2004 | 03:29 AM
TechSmurf's Avatar
Engine: LS1, Scrap
Not quite. You still want to reuse the 3.1 intake manifold+plenum. The 3.4's FI system won't directly plug into the 3.1's harness AFAIK.
Old Jan 18, 2004 | 08:57 AM
Dale's Avatar
Engine: 350 S-TPI
Take your 3pieces of the intake, swap over.
Move your timing chain cover over. Inspect/replace chain while here.
Swap your distrib over.
pull the 17lb injectors from the 3.4, and plug them into your 3.1 rail with new o-rings.
project85 says oil pan will clear, but for complete stealth mission, swap it too.
Two sensors, one in top front of engine, cam sensor, leave it in to plug the hole. One on pass side block, down low. Leave it in.
Pass side engine, remove knock sensor, swap to other location down by starter. Take plug from other location and put in orginal knock sensor location.
Old Jan 18, 2004 | 10:16 AM
Engine: 5.7 / 7.4
3.1s have kanock sensors
Old Jan 18, 2004 | 11:33 AM
Dale's Avatar
Engine: 350 S-TPI
yes they do. I had to replace the end of the wireharness to mine
not a fun project
theurge
Aug 21, 2015 12:46 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
92projectcamaro
Aug 6, 2015 01:20 PM
