Headers For 3.4L
Old Jan 17, 2004 | 06:44 PM
FbodTrek's Avatar
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
Headers For 3.4L
Found some headders for the 3.4 for only 200 bucks! They cxarry ceramic coated ones for just over 300. www.texas-speed.com . I wonder if they'd work on the 2.8, 3.1 too?
Old Jan 17, 2004 | 09:42 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
if they are for a 4th gen camaro or bird, they will fit but require some bending as i understand it. the will bolt up to the heads though if that's what you're wondering.
Old Jan 17, 2004 | 09:57 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
https://www.thirdgen.org/techbb2/sho...rebird+headers
Old Jan 17, 2004 | 10:10 PM
FbodTrek's Avatar
If
If the 3.4 manifolds will bolt up to a stock Y pipe, why wouldn't the headers? I assume the 4th gen owners don't go out and have a Y pipe made when they put them on. There is less space around a fourth gen V6 motor then around the thirdgen..... why would it need extra space?
Old Jan 17, 2004 | 10:22 PM
Engine: 5.7 / 7.4
there are differences in the firewalls, and teh y-pipes are routed differently between the 3rd & 4th gens.
PLus, the headers usually come/the matching y-pipe.
Old Jan 17, 2004 | 10:56 PM
FbodTrek's Avatar
If that's the case...
How come I can drop a 3.4L in my thirdgen with the 3.4 manifolds, and have it bolt up? (you know, I'm seriously thinking of designing a set of headers for 3rd gen V6's....) If anyone can tell me where to get a 3 part collector, or whatever the thing is called that joins the three pipes? lol
Old Jan 18, 2004 | 09:50 AM
eric17422001's Avatar
Car: 3
Engine: inboard
Transmission: underfloor
To answer your question: YES the 3.4 will bolt in, the manifolds on that 3.4 will work as the outlet of those manifolds exits in a location where the body of the car does not interfere with it.
The 3.4 headers you are looking at were built for the 3.4 when INSTALLED IN A 4th GEN CAR.
Look at any headers and you will see they take up more space in an engine compartment than manifolds, in this case, the 4th gen 3.4 headers hit the firewall of the 3rd gen cars.
Eric
Old Jan 18, 2004 | 10:00 AM
Lee7's Avatar
Car: 88 BMW 535i
Engine: 3.5L M30
Transmission: 4HP22E
you can heat up the headers for a 4th gen with a propane torch and then bend them to clear the firewall, so they WILL fit with a little work.
Then you can take the car down to a muffler shop and have them build you a Y-Pipe.
Old Jan 18, 2004 | 06:02 PM
V6sucker's Avatar
Car: a car being parted out
Engine: blown up
Transmission: in peices
the ones he posted a link to are shorties...
so, we need to get a pic and see what they consider "shorties"
Old Jan 19, 2004 | 07:28 AM
KED85's Avatar
PaceSetter makes street legal headers for the 4th Gen 3.4
I'm hoping to be leaving in a few days to go to Phoenix for having street legal headers made for the 3rd Gen & my car used as the mule for that purpose.
"Mule" is an engineering term for the "mock up/fitment".
With the street legal headers for V6 in 3rd Gen, one will also need purchase the better flowing "Y" pipe. This "Y" pipe will also be made by PaceSetter
Contact
Fgerle@pacesetterexhaust.com to express interest in this product for our 3rd gens running V6.
All the stuff from the 3.4 motor will fit under hood of 3rd Gen. The 4th Gen 3.4 mnifolds are nearly 99% identical to the 2.8/3.1 manifolds. There is ZERO increase in flow with a 3.4 manifold, it's as lousy a design as the 2.8/3.1 item.
The 3rd Gen "T" pipe sucks as a design for performance, any way ya look at it.
Look down your engine bay passenger side exhaust system to see why.
What can ya do to the factory 3rd gen set up?
NOT MUCH.
Add a better flowing Cat Convertor, increase the rest of the pipe size to 2 1/2" & add a better flowing muffler.
IF ya want to keep factory exhaust manifolds, it's not so difficult for an experienced muffler shop to create a better flowing "Y" pipe for our 3rd Gen V6 ride.
If ya stick a 3.4 under your hood, as I have (twice) the original vehicle factory "Y" pipe bolts back up just perfect, with no modifications required.
Old Jan 19, 2004 | 09:06 PM
V6sucker's Avatar
Engine: blown up
Contact
NOT MUCH.
was wondering where you went with the header stuff...
NZKnight
Oct 15, 2015 02:47 PM
redformula88
Oct 14, 2015 06:08 PM
Bradsaundry
Oct 7, 2015 04:35 PM
91 SrS
Oct 7, 2015 04:32 PM
Bigold4x4
Sep 28, 2015 05:21 PM
