2.8 Problem
Old Jan 21, 2004 | 09:30 PM
camaro350man's Avatar
Car: 1988 Pontiac Firebird
Engine: 2.8 Lt
Transmission: 5 Spd
2.8 Problem
Parked my firebird in the garage tonight and did some break work. I put new shoes in the back. I also put new wheel clyinders in. Now just need to bleed them. Now for the problem. I go to start the car. It starts runs right up to 1500 rpm like it usually does. Then dives down to 500 rpm and then lower then the car stalls. There was a ton of blue smoke also. Tried to start it again and just sputtered like it wanted to start. Then nothing, and just kept turning over. My fuel pump is working. I don't know what to do. I know I am getting spark. Any ideas?
Old Jan 21, 2004 | 09:35 PM
Engine: 2.8 Lt
Transmission: 5 Spd
The car is a 1988 Firebird 2.8 Multi-Port. It has a 5 spd also.
Old Jan 22, 2004 | 12:33 AM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Blue smoke is never a good sign. That generally means oil. Check your oil and water for contamination...maybe it's a head gasket problem. It's hard to imagine it would run fine and turn off and then give you problems like that after just sitting there though.... You usually have to be really beating it to have something like that happen.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
383cam
Sep 9, 2015 06:01 AM
snakeshooter
Sep 7, 2015 11:13 AM
rjcme
Sep 5, 2015 01:23 PM
andy74
Sep 3, 2015 08:41 AM
