The Day Has Come!!
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
The Day Has Come!!
My awaited day has finally come. I don't think I have to say what these pictures are
:lala:
Was nice to meet someone from here face to face. Thanks Project85!
:lala: Was nice to meet someone from here face to face. Thanks Project85!
Engine: 350 S-TPI
About 12 hours of labor later.... Stripped all way down, cleaned, painted, antifreeze plugs almost replaced. Heads are about half ported (need spring compressor).
Car: 88 IROC
Transmission: Pro 5.0 shifted T56
Axle/Gears: 10 bolt 3.73 posi
So exactally what are you doing? Please tell me you didnt go to all the work of pulling your motor and taking off the heads just to paint it....Whats goin on here...
Engine: 350 S-TPI
that is project85's old 3.4l engine that I meet halfway and picked up yesterday. My engine is still in car so I can drive it back n forth to work.
Knowing hit had cought on fire, and I plan on SCCA'ing the car its going to go in, I pulled heads to do some porting, plus have machine shop do some work, and replace gaskets/seals check levelness due to excessive heat.
Plan is a hybird of about 5-7 different engine parts plus some aftermarket parts.
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
*drooool* I want one.. my turbo would be so happy.. but.. I need to do so much work to the rest of the car for it to handle that kind of power.. *sigh*
Engine: 350 S-TPI
I think it was from a 95 bird, transplanted/hybrid to 85 bird, now will be re-hybrid to a 91 camaro
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
Good to see you made it back
It ended up being a 15hr trip for us, but we did get to see DA PATS in New Orleans
I might even order the gaskets down here & bring them up.
Motor from a 94 Camaro, and now new one from 95 Camaro. THey make great donor cars
I may pop in from time to time to check on progress.
I might even order the gaskets down here & bring them up.Motor from a 94 Camaro, and now new one from 95 Camaro. THey make great donor cars
Engine: 350 S-TPI
If project got it from ebay, I dunno. I wasnt around here at that time. My evilbay one went in the truck.
OPS, 94 Camaro, o well, almost same thing
15 hours
Damn that was a long haul. so you guys got in at about 11, geesh, long drive for you guys.
15 hours
Damn that was a long haul. so you guys got in at about 11, geesh, long drive for you guys. Thread Starter
Engine: 350 S-TPI
Update
Coolent passages flushed
5 out of 6 brass plugs in.
Both heads internally de-bured, and ready for machine shop.
Timing cover off, finding very worn timing chain
new tc cover and pan ordered.
Oil mount found and cleaned, laying on engine.
RedLeader289
May 28, 2019 01:47 PM
