Car won't start
Old Feb 10, 2004 | 03:59 AM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
Car won't start
alright guys i was leaving my gf's house and i started my car seemed fine just didn't crank all the way the first time, si i tried it again and nothing, i hear a click my battery is fine i'm pretty sure its just my starter and id on't have my service manual with me
any ideas?
Old Feb 10, 2004 | 05:58 AM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
If the solenoid clicks over and nothing happens:
Low battery amps (hook up DMM to battery while cranking.. check voltage drop.. <10v bad, though a bad starter can show this too, as well as excessive attempts to get it started)
Bad connection to battery (a decent amount of corrosion will make it very hard to start.. make sure terminals are clean. hook up DMM to a positive lead in car, if voltage drops to near-zero during a cranking attempt and recovers back to 12v, this is likely)
Bad connection at starter (unlikely, but check)
Hydrolocked motor (fluid in cylinders *or* too much oil in crankcase)
Hosed starter
Old Feb 10, 2004 | 11:14 AM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
alright the problem is i have no tools available and i'm about 40 km from home, any idea on how to get it going so i just get it home? i was gonna try a push start but my gf can't push my car and her dad has a bad back so i'm kinda sol
Old Feb 10, 2004 | 11:25 AM
flrtin1's Avatar
Car: Z/28..39 Plymouth truck in progress
Engine: S/B
Transmission: Manual
if you have cables try to jump it because sometimes the higher amperage of a running system will overcome the voltage drop wherever it is, worth a try though to get it going and get you home
Old Feb 10, 2004 | 11:30 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Try jump starting it with a bigger car. This time of year battries crap out. Usualy you get a dead cell. It will seam fine until the batt get so low then it will never regain or recharge.
Old Feb 10, 2004 | 11:35 AM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
alright i'll give jumping it a try
Old Feb 10, 2004 | 01:33 PM
TechSmurf's Avatar
Engine: LS1, Scrap
http://www.sears.com/sr/javasr/produ...id=00965114000
This box fits almost perfectly in the rear storage compartment. I manage to carry one under my 12"x2 speaker enclosure. Can hold 90% of the tools required to completely dismantle your car, and comes with a very friendly price tag.
Perhaps her dad could sit in the car while you and your girl push? Maybe a neighbor would be willing to help push?
Jump start from a car with a beefy charging system is also a good idea if it is indeed the battery.
Old Feb 10, 2004 | 03:08 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
it was as i suspected a blown solonoid, she starts fine now
midge54
Dec 27, 2019 04:14 PM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
ZsTransAm
Aug 11, 2015 07:30 PM
killer777
Aug 8, 2015 02:47 PM
