AFPR for our cars?
Old Feb 11, 2004 | 11:52 PM
FbodTrek's Avatar
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
AFPR for our cars?
Which ones will work? Which ones are cheap?
Old Feb 12, 2004 | 05:48 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I know holly will. Their is some otherone that is blue that will work.
Old Feb 12, 2004 | 05:51 AM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Yep, Holly one works like a charm!
JET makes one, too...
Old Feb 12, 2004 | 04:06 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
how much do these cost?
Old Feb 12, 2004 | 05:02 PM
bes217's Avatar
anyone have part numbers?
Old Feb 12, 2004 | 07:25 PM
Dale's Avatar
Engine: 350 S-TPI
http://store.summitracing.com/partde...LY%2D512%2D501
Old Feb 13, 2004 | 12:55 AM
bes217's Avatar
OMG!!! 90 dollars. Is it really worth it??
Old Feb 13, 2004 | 07:55 PM
Doward's Avatar
Vortex Performance is thinking of building one. It'd be $65. Anodized red.
Old Feb 13, 2004 | 10:10 PM
Car: 91 Camaro
when can we get them??
Old Feb 13, 2004 | 10:46 PM
Dale's Avatar
Engine: 350 S-TPI
doward=vortec performance.
What he would be doing is maching and outside, with a sealproof screw on the middle to make it adjustable.
Old Feb 14, 2004 | 12:02 AM
Car: 91 Camaro
doward AND vortex = vortex performance...his buddy adam, i think is the main one of vortex performance.
Old Feb 14, 2004 | 05:43 AM
KED85's Avatar
IF you take the 3.4 fuel pressure diaphram & replace the 2.8 one, inthe original 2.8 housing you're fine.
It's cheap, too.
Old Feb 14, 2004 | 08:19 AM
Doward's Avatar
AM91's correct... Vortex is the 'Vortex' in Vortex Performance... or something like that... LOL
Yeah, ours would be modified stock ones, adjustable, with a completely new diaphragm/spring assembly. Considering the cost of anodizing, it's more a way to get some recognition, than to actually make some money! LOL
The first one will be put on the Turbo mule.... so stay tuned!
Old Feb 14, 2004 | 10:57 AM
bes217's Avatar
But, what kind of gains will we see from putting one on?
Old Feb 14, 2004 | 12:06 PM
FbodTrek's Avatar
From my understanding
)you wont see too many gains at all unless you have some breathing modifications already (cam, headders, exhaust). A motor can't benefit from more fuel until it has more air to burn it. By the way, KED, did you use the 3.4 regulator internals on your swap? I have the whole 3.4 regulator and it's in excellent shape. Skrew it, i'll swap it today, got nothing else to do (except change Sonars fuel pump)
Old Feb 14, 2004 | 08:37 PM
bes217's Avatar
I have headers and full exhaust, 160 degree therm, intake, and a chip but thats it. Will I get gains?
Old Feb 14, 2004 | 09:01 PM
KED85's Avatar
Exactly correct!
Since the 3.4 Fuel Pressure regulator will not "fit" the 2.8 fuel rail, I opened up the 3.4 one & opened the 2.8 one, swapped 3.4 guts into the 2.8 housing & closed up.
This worked perfect.
Incidentially in my swap/upgrade, the rubber diaphram in the 3.4 pressure regulator was in perfect shape & the original 2.8 rubber diaphram was torn.
I was also told I could add a nickle (acting as a shim) to the spring & increse pressure this way.
I mearly placed my 3.4 spring inside the 2.8 housing.
I only did this Fuel pressure regulator swap/upgrade as cheap insurance (meaning the 1995 3.4 stuff was only 10 years younger than my 1985 stuff).
Old Feb 15, 2004 | 03:03 PM
Lee7's Avatar
Car: 88 BMW 535i
Engine: 3.5L M30
Transmission: 4HP22E
Re: From my understanding
you will get more power from better fuel atomization.
this is from the Thirdgen.org FAQ section:
Code:
Q: What fuel pressure setting will give me the best performance?
A: The stock setting is 42 PSI. Much track testing has showed that any type of increase will greatly benefit both horse power and torque. Here's some dyno testing on a stock 350 motor which substantiates those claims:
          42 PSI (stock)           46 PSI                    50 PSI
   RPM     Torq     HP      Torq/diff    HP/diff      Torq/diff    HP/diff
   2250    237.7  101.8    254.9/17.2  109.2/ 7.4    275.0/37.3  117.8/16.0
   2500    241.7  115.1    262.1/20.4  124.8/ 9.7    283.3/41.6  134.9/19.8
   2750    241.5  126.5    275.2/33.7  144.1/17.6    297.0/55.5  155.5/29.0
   3000    237.1  135.4    278.2/41.1  158.9/23.5    305.5/68.4  174.5/39.1
   3250    233.8  144.7    278.9/45.1  172.6/27.9    311.3/77.5  192.6/47.9
   3500    241.0  160.6    278.2/37.2  185.4/24.8    309.5/68.5  206.3/45.7
   3750    246.6  176.1    283.4/36.8  202.4/26.8    303.3/56.7  216.6/40.5
   4000    250.4  190.7    278.3/27.9  212.0/21.3    298.0/47.6  227.0/36.3
   4250    251.6  203.6    272.5/20.9  220.5/16.9    289.1/37.5  233.9/30.3
   4500    253.5  217.2    257.3/ 4.2  220.5/ 3.3    277.0/23.5  237.3/20.1
   4750    245.0  221.6    242.1/-2.9  219.0/-2.6    266.4/21.4  240.9/19.3
   5000    227.6  216.7    225.0/-1.4  214.2/-2.5    237.8/10.2  226.4/ 9.7
Old Feb 16, 2004 | 10:01 AM
Doward's Avatar
I don't know about dyno numbers - but I'm hoping to have track numbers from the VP AFPR this weekend, if I ACTUALLY get a Saturday off!
Old Feb 16, 2004 | 10:25 AM
KED85's Avatar
I hope your testing bears fruit! In your egine combination, I certainly believe you will see gains.
Not to dump on the stated test results, but a 350 cubic inch sized engine fuel management system will injest "More..." then an engine sized fuel management system of a 217 Cubic Inch (3.4).
Plus to add more "dump", I'd say an engine using 6 cylinders would show "different" results, than an engine using 8 larger cylinders.
NOT Dumping, just throwing out a few other thoughts.
Old Feb 16, 2004 | 10:57 AM
Dale's Avatar
Engine: 350 S-TPI
I am hoping to bump mine up to about 44-45'ish psi.
Found some parts, and its in my welders hands right now. This is modifying a "stock" one also.
Just wish I could get my damn heads back today
Old Feb 16, 2004 | 11:54 AM
FbodTrek's Avatar
Dangit!
Mine is spiking at 45 psi right now, problem is I have instant bleedoff . Guess I need to do what we did to Sonars Trans Am last weekend-swap the fuel pump. Apparently I have a leaking check valve or somthing. The Regulator housings are the same too by the way, so are the part numbers on the diaphrams. I used a Dime for a shim....I guess I need another nickel
Old Feb 16, 2004 | 12:14 PM
Dale's Avatar
Engine: 350 S-TPI
Sure its not your injectors leaking off? Its more commen then fuelpump bleedback.
If you swap pumps, install a camaro v8 one, or corvette pump.
I knew the v8 regulator, and v6 regulator are the same. Just how many v6 guys wish to spend 80-100 bux for an adjustable one vs v8 guys?
Old Feb 16, 2004 | 06:53 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I have the same thing on my car (pressure drops right to zero), diagnosis with my GM service manual tells me what dale just said- it's a leaking injector. You'd think I'd fix it soon... inspection was last month. (Oops) I'm sticking to driving at night on major highways so I don't get pulled over
Old Feb 16, 2004 | 10:13 PM
KED85's Avatar
Wave Hi to Barney Fife of Ewing Township as you sneak thru!
Old Feb 16, 2004 | 10:20 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Wouldnt a leaky injector show more signs? Wouldn't it get into the oil and thin it down and also smeel of gas? 45 psi is allot of fule to leak out into one cylinder. It should also blow some crap at start up?
Old Feb 16, 2004 | 10:24 PM
FbodTrek's Avatar
It's not a leaking injector.....
They are good injectors. The same thing was happening when the 2.8 was in the car. There is a check valve that wears out, that's what it is.
Old Feb 17, 2004 | 12:25 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Well, on my car, I went through my GM service manual diagnostic chart, and it told me it wasn't the check valve. Did you run through the chart on your car?
This is out of sequence, but I had to crimp the return line AND feed line closed, so the only "outlet" for fuel pressure was to the injectors- and the pressure still dropped.
I believe it's my CSI since I had sent the 6 injectors out to Rich J at cruzinperformance.com to be cleaned a few years ago, but never sent him the CSI. My car is also hard to start when cold, and always smells rich...
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
