how do you REMOVE the COIL??
Old Feb 15, 2004 | 04:25 PM
squirrelybird's Avatar
seems that two clips hold the coil in place, one on each side. the clips are riveted in, not screwed or anything. how do you remove the stock coil, and how do you replace it?
thanks
Old Feb 15, 2004 | 04:38 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
you have to use a chisel to get the rivets off.
Old Feb 15, 2004 | 04:40 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
a chisel or I used a drill and bit. Not easy at all.
Old Feb 15, 2004 | 04:43 PM
Engine: LH0 3.1L
Originally posted by Gumby
Not easy at all.
It takes like 2 minutes. It's easier if you pull the whole bracket off the engine though.
Old Feb 15, 2004 | 04:52 PM
i could have figured that much, but then how do you put the new one on??? i have no rivet gun, and may consider remote mounting it later, but right now i just want the car running. i have seen mounting kits that use screws....is this what you use after cutting off the old rivits?
Old Feb 15, 2004 | 05:15 PM
Engine: LH0 3.1L
Every coil i've installed comes with a couple bolts/nuts to replace the rivets.
Old Feb 15, 2004 | 06:20 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I'll second that. If it didnt, go to a hardware store with coil in hand. Find the largest bolt system that fits in the holes with nylon locking nuts on the other end.
Will need 2 log ones, 2 short ones, 4 nuts.
Old Feb 15, 2004 | 07:58 PM
Kj Rockz's Avatar
From: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
its a real pain in the ***.
I just took mine intothe shop before i fu(ked it up more
Old Feb 15, 2004 | 08:14 PM
br()bert's Avatar
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
i smacked my old dead one with a bigass hammer . It was dead anyway.came right out.
Old Feb 15, 2004 | 10:56 PM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
dremel + cut off wheel.. carefully nuked the rived head, then tapped out rivet with a punch. Should take less than 5 minutes with the bracket out of the car, no matter which way you go about it.
Old Feb 15, 2004 | 11:34 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Its real hard to do when installed. It hard enough getting your finger on everything to bolt it down right at all 4 corners. No room and lots of crap in the way. I only messed with it once and moved it to my cowl.
Old Feb 17, 2004 | 06:55 AM
ok thanks for the help guys. i used a dremel on the top two...then realized the bottom two went straight through the coil, and had to be removed also! i just used a screwdriver and a hammer for those, no problem.
soooo, i know you guys recommend mounting it somewhere cooler, maybe on the firewall. well the bolts that came with my new coil use nuts to hold the back. what did you guys use to mount on the firewall, with no access to the backside? sheet metal screws??
thanks, evan
Old Feb 17, 2004 | 12:14 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
This is what I did... my stock coil was still good when I upgraded, so I left it in as a "spare" in case my car died on the road. This way I could plug the original coil back in, and if the car started, I'd know it was my coil.
Old Feb 17, 2004 | 12:17 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
By the way, that bracket I made (from 1/8th inch steel "strip stock" from Home Depot's hardware aisle) doesn't actually bolt to the heater/evaporator box. There's a little cross-brace that I sandwiched in there (by removing the top of the heater/evap box, putting the assembled bracket's "T" in, and screwing the top of the box back down). Here's a quickpik-
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
morrow
Jan 13, 2024 12:29 PM
Stryker412
Sep 7, 2015 09:11 AM
TheExaminer
Sep 6, 2015 11:40 PM
RyanJB
Sep 2, 2015 01:27 PM
