Oil PSI too high??
Old Mar 5, 2004 | 01:40 AM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
Oil PSI too high??
Lately ive noticed my oil pressure is 60 at idle and around 80 when im driving any ideas why it is doing this? Is there somethign lurking around the corner i should know about that i can prevent
Old Mar 5, 2004 | 01:42 AM
br()bert's Avatar
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
did you
change the oil lately with some heavier oil? That will make the oil pressure raise some.
IS the pressure still the same once the car warms up?
Hey its better than it being too low...
Old Mar 5, 2004 | 01:44 AM
FAST RS's Avatar
I changed the oil with the same weight 10-40 Only thing different is i put a quart of marvel mystery oil in for my lifters and it did quiet them down allot but the mystery oil is very thin so i dont think that would cause it.
Old Mar 5, 2004 | 01:55 AM
br()bert's Avatar
Car: 85 firebird
how long ago did you change it?
Did this happen right after you added the mmo?
Im just guessing here but i know mmo is supposed to clean the inside of the engine pretty good so many be it cleaned some junk up and the junk is partially clogging your oil filter? That would make the oil pump try harder and raise pressure wouldnt it?
If its been awhile or you've drove for a distance long enough for the mmo to work through the engine i'd chenge the oil and or the filter again
Old Mar 5, 2004 | 04:07 AM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
Actually, that would be a sign of seriously improved efficiency in the oiling system.. like.. right-out-of-the-factory or higher oil pressure... this is generally a *good* thing, unless the MMO sent a clog through that gummed up the oil pressure relief bypass, which isn't likely.
I think you just posted the most comprehensive proof we have that the stuff works.. I think I'm investing in a few gallons
Old Mar 9, 2004 | 09:54 PM
Slow2.8's Avatar
I wouldnt worry about it. I use synthetic and those numbers match up to mine, 60 idlin and i do hit the 80's while driving.... it varies though on my car, but its usually high. I dont think its anythin to worry about. Before i changed my oil it was ruff at 20 psi, so im just glad i got it flowing better!
Old Mar 10, 2004 | 05:26 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
You people suck... Wish I got that kinda oil pressure outta my brand new motor. 25-30 psi at idle, and rarely passes 40. :P
60 is pretty awesome.
Old Mar 10, 2004 | 05:36 PM
FAST RS's Avatar
And i have 230,000 miles on my 3.1
Old Mar 10, 2004 | 11:26 PM
TechSmurf's Avatar
Engine: LS1, Scrap
Put about half a quart of MMO in my V6 today.. probably be a little while before she racks up enough miles for any difference to be seen.. I'll let you guys know what happens though.
Old Mar 10, 2004 | 11:31 PM
badandy247's Avatar
Car: 91 Camaro RS
Engine: 3.1L V-6
Transmission: Fresh 700R4
pressure sender is bad on mine
idle 70-80
driving OFF THE FREAKIN SCALE!
Old Mar 11, 2004 | 12:11 AM
FAST RS's Avatar
any one know how MMO would work with fuel injectors and fuel pump it says you can put it in your gas. Would it hurt anything?
Old Mar 11, 2004 | 08:59 PM
TechSmurf's Avatar
Engine: LS1, Scrap
I recall a previous thread going on about MMO in the fuel system.. searching might be an idea.
As far as mine, there's a full quart of MMO in the V6 now.. it's having little effect on my hot idle oil pressure.. still under 20 psi. Impending internal doom or just an unhappy turbo, I cannot say.. but it looks like my only way out will be a high volume oil pump for now. I'll bring this thread back if anything changes to prove to me MMO works in extreme cases
Old Mar 11, 2004 | 10:46 PM
FAST RS's Avatar
I did a search and could not find any info on putting MMO in the gas i foudn it with cars that were carb'd but not fuel injected. Any one ever try it with a FI car?
my86bird
Oct 23, 2015 12:20 PM
Gunsbee
Sep 7, 2015 07:10 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
Navy8125
Aug 21, 2015 09:32 AM
355sbcTPI
Aug 19, 2015 04:38 PM
