Where are the neutral switch and reverse light wires on an auto
Old Mar 12, 2004 | 07:58 AM
camaro_V6_Tuner's Avatar
Car: 2002 Trans Am WS6
Axle/Gears: 4.10
Im in the middle of my auto -> manual swap and I am trying to find the wires for the reverse lights and the neutral safety switch. The only wires I found that look even close to the wires on the clutch switch are on a 6 wire connectiong that was in the center console. This makes sense but Im not sure if they are the right ones. They are purple and yellow.
As far as the reverse light wires go, I have no clue where they are. I assume they would be on the same connection as the neutral wires but I am not sure which wires they are and what the other 2 wires would be for.
Little help?
Old Mar 12, 2004 | 08:37 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
do you have a manual or wiring diagram? also try checking on the electrical board. this probably isnt the best message board to find an answer like this
Old Mar 12, 2004 | 08:50 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The neutral & reverse wires for an auto are connected to the switch by the shifter. IOW: they are shifter activated.
If the purple wires are a larger-then-normal size then they are the park/neutral safety wires. Common color for GM vehicles.
Don't know the year of your car, but if it has an airbag then the yellow wires may be for one of the sensors. IIRC there is a sensor mounted under the console in that area.
RBob.
Old Mar 12, 2004 | 09:11 AM
Axle/Gears: 4.10
my car is an 87 camaro 2.8 originally auto. no airbags
Old Mar 12, 2004 | 10:06 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
i answered you in your other thread in electronics..
its the blue and green wires on the shifter connector... the two CLOSEST to the thicker nutural/clutch wires.
Old Mar 12, 2004 | 11:48 AM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
MrDude_1, they changed the wire colors in 1990. That info doesn't quite work for this. I've answered this in the other thread, but I guess I'll toss the answer in here too
82-89 only:
Reverse Switch: Dark Blue - Light Blue
P/N Starter Switch: Yellow - Purple
P/N ECU Switch: Orange/Black - Black
Old Mar 12, 2004 | 01:17 PM
Axle/Gears: 4.10
ok, thanks guys, but then what is the point of those 2 other wires (the orange/black and the black ones) and where should they be wired to?
Old Mar 12, 2004 | 01:30 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
They go to the ECM so that it knows whether the trans has been placed into drive or is in park/neutral.
For a stick car leave the orange/blk wire open. The black wire should be tied to ground. So can just leave them both open. With a stick car the ECM is left believing that the trans is always in drive.
TechSmurf, it is funny how after so many years of using the same color purple for both ends of the safety/neutral switch GM up and decided to make one yellow. I wonder if maybe they got a good price on a bunch of yellow wire.
RBob.
Old Mar 12, 2004 | 01:35 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
RBob.
i forgot about the change myself.... GM did keep the wires the same from then until present....
i should have remembered the otherones were blue.... i had a 82 camaro that i wired up for the same thing.
Old Mar 12, 2004 | 01:58 PM
Axle/Gears: 4.10
RBob,
if the computer thinks the car is always in drive, you wont be able to start the car will you? From what I remember, you were not able to start the car when it was in drive with the auto tranny. I guess Im confused......
Old Mar 12, 2004 | 02:02 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
RBob,
thats what the two thick wires are for.
the two thick wires are your starter lockout.... when it was a auto, they were connected only in park and nutural
now that you have a auto, you need to extend the wires to the switch that gets press when the clutch is too the floor. that way, you cannot start the car until the clutch is in.
Old Mar 12, 2004 | 05:11 PM
Axle/Gears: 4.10
thanks, i got it now
BRoss99
Aug 10, 2025 05:08 PM
The_Phoenix
Feb 4, 2016 07:10 AM
BewleyBizzIROC
Aug 14, 2015 02:52 AM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
