clicking injectors after shut down?
Old Mar 18, 2004 | 05:59 PM
br()bert's Avatar
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
Ok my runs great but i have noticed after i shut it off i hear what sounds like the injectors clicking. Like in order, the noise slows to a stop after like 6 seconds. I first thought it was heat tick, like when your motor is hot and you shut it down sometimes you hear a tick sound, but it sounds like the injectors.
Like i said the car runs good, any ideas? Simular symtoms?
Old Mar 18, 2004 | 06:03 PM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
never heard of this one b4, when i read it i was thinkign heat tick too, metal expanding and now contracting....woudn't expect the injectors to continue firing after power has been killed to the computer, seems a lil off...or maybe it just seeems a lil off to me.
Old Mar 18, 2004 | 06:08 PM
br()bert's Avatar
Car: 85 firebird
I thought it was heat tick too untill i started the car, ran it for 10 seconds and shut it off and heard the same sound, all in 35* weather. The injectors is the closest i can come to explaining what it sounds like, it even sounds as if they are clicking in firing order.
Old Mar 18, 2004 | 09:09 PM
br()bert's Avatar
Car: 85 firebird
anyone have any ideas?
Old Mar 18, 2004 | 10:40 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Let's see if this pc works this time....
The injectors don't fire in the timing order, they are a batch feed, which means the ECM just provides a ground for them at the proper time on one bank at a time and they fire.... If you have your Haynes handy you will see what I mean-they are wired in parallel so they all go off at the same time when the ECM provides the ground....
Old Mar 18, 2004 | 11:26 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
That's what my ride was doing after the "Great Fire of '03" , when the harness got fudged up
Car even shut down on me 3 times and still did that clicking crap, even w/key out of ignition.
Old Mar 19, 2004 | 10:10 AM
br()bert's Avatar
Car: 85 firebird
i wonder why its doing this
bbsr72
Sep 27, 2015 05:55 AM
Linson
Sep 21, 2015 01:08 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
IROCZ1989
Sep 4, 2015 11:54 AM
