Intake
Car: 99 SS
Intake
Off topic for a moment, but sadly the camera messed up the pics for the suspension replacement so I won't be posting them.
I know some people tend to disagree with this method a little bit, but... Here's a little something I'm rigging up in my intake. Couple of Nidec fans I got for really cheap. The lowest figures I have for them they will flow 500 cfm total at 1/4-1/2 psi, highest figures I have are 700 cfm total with 1 psi. I'm believing the 500 at 1/4 to 1/2 the most just to err on the lower side.
I'm going to wire a micro switch and relay to the throttle so that when I'm at idle they will be off and when I step on the pedal they will kick on. Also going to wire a master switch inside the car so that I can have the option of driving with or without them on.
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
I've never gone for the whole electric supercharger thing...but hey, 500+ cfm aint bad at all for one of those little fans. I'm always open for new ideas... I'd be interested to see if it helps at all. How quick do those fans 'spool'?
Car: 99 SS
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
Just like ram air..
I think it could work, bilge blowers would be better, but hey, for 5 bux you can't go wrong. it can't hurt the motor (as long as you use a filter between the fan and intake).
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
Don't get me wrong here, I'm all for trying out new things, but I seriously doubt that you will be seeing any kind of difference from them. With your max number of 1 psi, you will only get a reduction from ambient air pressure (~29 in.), so you are now looking at 28 in at WOT. I can do that by driving the car when a storm is coming in.
Right on for trying something new, but don't get your hopes up...and for $5 and some creativity, it should be fun anyway just to screw with something.
Car: 99 SS
Car: 99 SS
Why would you ever want to not have them on?? Just curious
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
As I said, with mine, it did actually force more air into the engine at idle.. enough to affect idle rpm by about 100... so, hey. there are gains to be had. Maybe not huge gains, but for 10 bucks, who's counting. Good luck with that.. make sure your air intake system is sealed REAL tight, or you'll vent whatever boost you would generate to atmosphere.
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
i see that one of your locations is in florida....when and what part? if you're near me, we could test it on my car, see if it does anything on it!
Car: 99 SS
Forgot my drill at school when I went to visit my girlfriend/now fiance (yeah, popped the question this weekend and 10 minutes later thought of how much less money I'm going to have to spend on my camaro
). So, fans aren't hooked up yet and next chance to do it looks like 2 weekends from now...provided nothing goes majorly wrong with the Saab tune-up I'm doing then. Same with the rest of the stuff sitting in the trunk of my car.
AM91-
Sent you a PM. Also, what kind of timing do you have? I'm assuming you're running nothing but 93 octane or higher.
). So, fans aren't hooked up yet and next chance to do it looks like 2 weekends from now...provided nothing goes majorly wrong with the Saab tune-up I'm doing then. Same with the rest of the stuff sitting in the trunk of my car.AM91-
Congrats man....you're one brave soul. Good luck.
Let us know how the little project goes...... Hell if you're ever down in this area for some strange reason, we can hook my G-Tech up and do a little testing.
Car: 91 Camaro
Originally posted by RedTtop5spd
AM91-
AM91-
Car: 83' Pontiac Firebird
Engine: 2.8 V6
I just have a hard time believing that, those fans can flow enough to produce any boost at above 1500-2000 rpm.
I mean have you looked at the insides of a turbo. The fins are a lot larger and they spin at 20000-50000 rpm .
I am just speculating, but still..........please do tell us how this works out.
Car: 99 SS
Car: 1986 Firebird
Engine: 2.8 V6
). And let us know how the testing goes. I have a feeling that the engine's pull will spin the fans faster then they'll spin themselves, but it'll be great to know the test results! Do those fans have a feedback as to what RPM they're running at? It'd be interesting to pop a reader on there to see if the fans run faster/slower/etc...
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
yup.
the motor will pull the fans faster.. eventually they'll reach the break down point, a fin or two will come off, and that'll be that.
id explain how a FAN cannot create boost like a impeller, or how it will just become a spinning restriction..
but honestly, i think this is the same dude i already explained this to at www.3rdgen.org ..... and he has filters between them for when they blow apart, so i'll just sit back and watch.
athough i wouldnt use K&Ns... id use paper filters... paper ones usually have a stronger steel mesh on the underside... you'll want that to keep the shrapnel out.
Car: 1989 C4
Axle/Gears: 307
Only in America.
Actually I think the idea will work at low RPM but might create a restriction as more air is demanded by the engine. Anything is worth a try though. If if fails you can just do what every other inventer does (prototype).
Car: 87 Z28
This idea is not good, it's exactly as Mr. Dude says, and it will be a restriction.
Car: 99 SS
Managed to free up my afternoon so I got it wired up today and was able to take it on a 15mph tour around the post to make sure everything was working how it is supposed to. Post police are all over the place today for some reason. I noticed a better throttle response, but at that slow a speed it's impossible to notice anything else.
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
Originally posted by TomP I have a feeling that the engine's pull will spin the fans faster then they'll spin themselves...
Car: 91 Camaro Vert
Everyone's entitled to their opinion.
seriously though.
if you want more part throttle power, you can remove the sheetmetal restriction in the throttle body.
it'll make it idle a lil higher (thats why they didnt do it from the factory) but she'll have tons more power... probly more then you want going around town.
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
seriously though.
seriously though.
Car: 99 SS
No, I'm not the same dude you explained it to on 3rdgen.org. Well, for the total of $10 that I spent a long time before this idea came up, it's worth a try. There are many things that give more power in different places...just trying an idea. Out of curiosity...do you know what rpm's I run my car at? What kind of driving I do? Where I'm looking for the extra little bit of performance? Is trying an idea where things seem to line up kinda close that bad an idea? Truthfully though, thanks for mentioning the concern about the fans blowing apart. I do know about what you are talking about and I did take that into consideration, however it's good to make sure all the bases are covered.
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
ok, freeze frame! whats this steel mesh = more power thing? how much higher idle? this will reduce fuel economy wont it?
Car: 91 Camaro Vert
unless your a complete moron that does 70mph in first gear or somthing queer like that.
i hope its WOT high RPM driving though.... post pics of the fins embedded in the paper filter. it'll serve as a nice warning to the next kid that trys this... i honestly feel bad for them since most of the time, the fans get eaten by the motor and the valves get fugged (or worse)
Checking the rpms is part of the testing I'm planning on doing. I can borrow a few things from a project I did in the fall to hook up and check the rpm's.
if they have the regular PC out RPM signal, theres several ways to log it.
if you're good at electronics, you could use a simple transistor circuit and log the data thru a extra fan connector on a motherboard, and then use some generic motherboard monitoring software.
i didnt say more power.
most flat paper filters have this strong steel mesh backing to keep the filter together.
when his fan blows apart, the stronger mesh has a better chance of catching the plastic pieces then the thinner K&N stuff.
you have to realize, hes NOT the first one to do this... matter of fact, hundreds of people have attempted it.. alot fragged their motors.... do a search for electric supercharger on any respectable car board, and you'll see what i mean.
Car: 91 Camaro Vert
oh, as for the sheetmetal in the intake mod.
think about it.
its the butterfly valve in the throttlebody.
the trick to having more power at part throttle is..................... open the throttle more.
think about it.
Car: 1986 Firebird
Engine: 2.8 V6
Wow; I wonder how long any motor would last without that butterfly valve. I also wonder if it'd be hard to start, since the motor would have 100% airflow but the TPS was telling the engine otherwise. Nobody try this at home! I don't need to know that bad!!
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Originally posted by Quick_Trans_Am
:werd:
:werd:
I do know a fan that has the CFM but not sure about pressure. They do well over 2000 CFM. I know cause them triangle 2000CFM air cleaners will bog it down. But its an AC fan.
Though compare to a big stereo system the converter for the AC fan wouldn't be that much more / maybe less.
But one your that far I know a place where you can get electric leaf blowers for $9.99 about $20 shipped.
Oh and if I were you, put MrDude_1 on ignore. Making a point is important but do it in a nice friendly way. Anyone who bashes just to bash gets ignored. Some people would die first from being nice than not breathing. Help peple, give an oponion but do it nicely.
https://www.thirdgen.org/techbb2/mem...serlist=ignore
Car: 99 SS
Alright, finally got a chance to actually take my car for a drive to Walmart. Noticeable gains on the low end, can definitly feel it in the seat of the pants.
No tests for gains on the high end...never get up there anyway cept on rare occassion. Maybe I'll actually have to drive 15 minutes over the the 1/8 mile strip and get some numbers one of these weekends.
Car: 91 Camaro Vert
i know im a ******* somtimes.
athough i dont think anything i said is a direct bash.
re-read my first post... then tell me if that isnt sound advice......
other then my lil tease about removing the butterfly for more performance, it was all technical. in a azsholish way perhaps, but technical none the less. i didnt attack him personally and call him a moron or anything... just stated why it wouldnt work, and whats probly going to happen.
Car: 91 Camaro Vert
lol, didnt even think of the TPS... athough it probly wouldnt matter... the MAP would see the pressure and correct for it... probly throw a TPS code.
Car: 1988 Camaro RS
Axle/Gears: 3.42's
Originally posted by 2_point8_boy
If you don't have a rev limiter, you'll quickly find out where your true mechanical redline is.
Powerslides with no rev limiter are no good. All she did was **** some oil in my driveway overnight, thank ***.
I'd love to see numbers on the little electric fan thing...just for the hell of it. I doubt any real gains but hey....you never REALLY know anything until ya try it for yourself.
Car: 99 SS
jerflash
Sep 24, 2015 03:11 PM
toronto formula
Sep 10, 2015 07:31 AM
e3pres
Sep 9, 2015 01:51 PM
