Max potential from a 2.8
Old Mar 28, 2004 | 10:09 PM
Xhiron's Avatar
Car: traded away 94 v6
Engine: vacant
Transmission: also vacant
I'm looking for opinions on the maximum possible tq/hp numbers with stock aluminum heads (1.72/1.42 valves) heads and a 3.4L type intake (or something similar to it) and around 10:1 compression.
Plus, 'exactly' how long/wide is a 60/v6? What about weight with aluminum heads?
I'm working on a new project and I need to know within an inch or so of the dimensions, weight is a general ballpark though.
Help is much appreciated, thanks.
Old Mar 29, 2004 | 05:47 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
i'm making about 215 (i think) at the crank on a N/A 3.1 the aluminum heads are not stock and you MUST use an intake from a FWD car or a custom made intake to run the aluminum heads. the compression will require new pistons or something. i don't know about the weight or length/width questions off hand.
Old Mar 29, 2004 | 09:02 PM
Xhiron's Avatar
Engine: vacant
Are those intakes the 2 piece design? And what did you do to the 3.1 to get 215? Mod list?
Andrew
Old Mar 29, 2004 | 10:05 PM
Car: 91 Camaro
those intakes are 3 piece. go to www.cardomain.com/id/am91camaro_rs my mods and stuff are there.
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
86maro_252
Oct 10, 2015 06:52 PM
usafirebird
Sep 29, 2015 11:58 PM
Gordonr1973
Sep 29, 2015 11:59 AM
spartanreaper
Sep 25, 2015 07:22 PM
