145 Cluster
Old Mar 29, 2004 | 07:48 PM
theratdude64's Avatar
Car: 95 Z28
Transmission: Built 4L60E with 3000 Stall
Axle/Gears: 3.23? I'm not sure
145 Cluster
What would be involved with gettin a 145 cluster in my V6? I found a good 84 cluster and I have an 86 2.8... Whats needed to go to that from the crappy big gas dummy light cluster? How much will stuff cost and where do I install the stuff?
Thx
Old Mar 30, 2004 | 02:55 AM
CC_HotRod's Avatar
Car: 1984 Camaro
Engine: V6
Transmission: 700 R4
Here is a link to the tech section where this procedure is explained...https://www.thirdgen.org/newdesign/tech/gauges.shtml
The hardest part is getting your hand in back of the cluster to pull out the speedometer cable. You will need to replace the oil sending unit. Which is located down by the oil filter. It is an easy swap I have done a few of them.
Old Mar 30, 2004 | 07:58 AM
RedTtop5spd's Avatar
Car: 99 SS
Anyone know a good place to find one of these other than a junkyard? Yards around here don't have anything.
Old Mar 30, 2004 | 12:41 PM
CC_HotRod's Avatar
Car: 1984 Camaro
Engine: V6
Try http://members.***.net/iroczdave1/
He is a good guy to deal with.
Old Mar 30, 2004 | 01:23 PM
Car: 95 Z28
does that mention anything special for a V6 to work with a V8 Tach? I have read it before and didnt see that
Old Mar 30, 2004 | 07:51 PM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
v6 will work w/ v8 tach, but v8 tach will be off cause the car it's in isn't v8....can ya swap em? doubt it, but what can ya do.
Old Mar 30, 2004 | 07:53 PM
Car: 95 Z28
how off? is it tolerable? lol or WAY off? isnt there a way to correct it?
Old Mar 30, 2004 | 07:56 PM
85f-bird's Avatar
Engine: 2.8L, LS1
believe it's 25% off....the prob is that the v8 tach is trying to read for 8 pulses from the ignition, while it'll only be getting six. if you swap to the cluster, u could add an autometer/sunpro tach on the steering column or pillar if you wanted. Don't know however what you'd enjoy, and i'm not sure if you can fix the tach. You'd think it'd be cheaper ot manufacture a switch or a risitor which could be changed for v6 to v8, but i guess sometimes even GM is an idiot....(happens a lot)
Old Mar 31, 2004 | 02:44 AM
camaro_junkie's Avatar
Car: '86 Camaro SC, '16 QX60
Engine: 2.8 V6 POWER, 3.5L V6 N/A
Transmission: T-5, CVT
Hey theratdude64, that car in your sig, is that your '86 SC? If so, why does it have the gfx and that hood? Did you put that on yourself?
Old Mar 31, 2004 | 05:52 AM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
You can swap the tach/oil pressure cluster out with like 3 screws. Need to replace both for V6 accuracy, plus it's a one piece unit anyway. go figure. You will need to find the tach/oil pressure setup from a V6 gauge cluster first, though
Old Mar 31, 2004 | 10:11 AM
Car: 95 Z28
I bought it wrecked, but I got all the pieces to it. http://www.ufba.org/viewmember.php?id=107 is my site on for my local camaro club. I had a green hood up and till last week, then I found this one for $75 Bucks I got the RS nose and IROC Tail lights and a security shade from a junkyard for $98. It doesnt have full GFX, just the front chin, and its messed up
Old Mar 31, 2004 | 10:44 AM
Car: 95 Z28
While we are talkin about eachothers cars, I noticed That your 2.8 is Turbo Tech Smurf
Any pics? any data on that? lol how much was that
Old Mar 31, 2004 | 01:16 PM
TechSmurf's Avatar
Engine: LS1, Scrap
That would be completely custom fabricated Note that the sig line is a link to a website, or a quick search should turn up other pics posted here and details.
Old Mar 31, 2004 | 01:19 PM
Car: 95 Z28
ya right after I asked I found that
Dude that is freakin sweet :hail: :hail:
How much HP you think and how fast is it?
You think you could beat a 2.0 TUrbo Eclipse? They are AWD so mebe once rolling....
Old Mar 31, 2004 | 01:26 PM
TechSmurf's Avatar
Engine: LS1, Scrap
Lol.. an eclipse gsx would eat me for lunch. Currently limited to 4psi pending an injector swap, and possibly a speed density swap. And I've got an oil pressure problem which is keeping her off the road, which I'll hopefully have fixed in 2 weeks *sigh*
The to-do list for this car is.. long.. very long..
Old Mar 31, 2004 | 01:27 PM
Car: 95 Z28
lol. You think youd fair well against it when in good working order? your engine is badass, I wanna do this or something *pic*
I plan on an LT1 T56 Swap, and Ive seen a rear turbo that goes where the muffler is, and actually works damn well... Id probally go that route IF i do a turbo
Old Mar 31, 2004 | 04:43 PM
Your car looks exactly the same as mine (originally), except mine has t-tops. (See sig below.)
Also, correct me if I'm wrong, but there are V6 145mph gauges out there, and they are the ones with a 6k redline on the tach. The V8s have one with a 5k redline. Again, I am just speculating, so correct me if I am wrong. Anyways, there are some on eBay if you look around (not advertising here), but none for me since I need one in kph not mph.
Old Mar 31, 2004 | 05:52 PM
Car: 95 Z28
Nope, highest V6 went was 115 :'(
I wanna buy just a V6 Tach, as in JUST it not the cluster, then Put it in a 145 cluster... anyone got one or know where one is?
THx
Elephantismo
Feb 13, 2019 12:51 AM
Kylej68
Exterior Parts Wanted
Sep 28, 2015 10:00 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
ChristinaMarie
Sep 11, 2015 06:28 PM
