Blinker?
Old Mar 30, 2004 | 08:06 PM
camaro350man's Avatar
Car: 1988 Pontiac Firebird
Engine: 2.8 Lt
Transmission: 5 Spd
Blinker?
Hey guys. Another prob now. When i click my blinker the light doesn;t flash inside the car like it used to. It just stays lit and the outside lights also don't work. When i turn my headlights on the blinker stays lit inside and does not flash outside. But when the lights are on its always lit even if i push the switch down. But with the headlights off it doesn't, it will shut off. Someone said i have a bulb out, what do you guys think? Dangerous to drive now
Old Mar 30, 2004 | 08:17 PM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
That would be a toast bulb or two.
Old Mar 30, 2004 | 08:23 PM
Engine: 2.8 Lt
Transmission: 5 Spd
So what do i do to find out? Do I have to rip the dash apart and just look at all of them? Any idea on what lights it could be?
Old Mar 30, 2004 | 08:47 PM
RedTtop5spd's Avatar
Car: 99 SS
Try the outside blinker lights. Should be one of them.
Old Mar 30, 2004 | 09:00 PM
Engine: 2.8 Lt
Transmission: 5 Spd
They work with the hazards on, could it still be that.
Old Mar 31, 2004 | 12:19 AM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
It's an outside marker bulb, check ur front headlight markers, and also check the corners. Essentially ,it's saying that they're not blinking, just staying on, and they're supposed to go between bright and nada, or bright and not so bright. Give it another try, and also try it w/ ur parking lights on and off....see if theres a difference.
Old Mar 31, 2004 | 02:22 PM
Engine: 2.8 Lt
Transmission: 5 Spd
Thanks guys, ya it was my front marker light. Never knew that it could affect that much. Learning something new everyday. Thanks guys.
Old Apr 2, 2004 | 10:47 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
This isn't on topic, but a quick FYI- my blinkers were really S-L-O-W... usually that means a dying battery/alternator/etc, but all my stuff was in top condition.
The blinker can was just worn out! A new one fixed the problem ($3)- I think I had to replace it around 215,000 miles? So I was going nuts tracing an electrical problem that didn't exist...
Old Apr 2, 2004 | 10:51 PM
85f-bird's Avatar
Engine: 2.8L, LS1
hey tom, do ya have a better description of a blinker can? just kinda curious i've got a slow blinker setup.
Old Apr 6, 2004 | 05:44 PM
Pyroja's Avatar
Car: None! =(
Engine: My own two feet.
Transmission: My, uh.. Knees?
I have a smilar problem.. My blinkers just decided to stop working. Even the blionker lights inside the car don't light up. But only if I use the turn signal lever thing. if I kick on the hazard lights, they all light up and flash just fine. So I'm uh.. Confused?
RABMAN
Interior Parts Wanted
Sep 18, 2015 09:02 PM
Jk_Under
Sep 2, 2015 10:59 PM
bklucas12
Jan 11, 2002 06:44 AM
super83Z
Jun 2, 2001 10:44 AM
Jimmy91RS
Sep 28, 2000 02:16 PM
