Turbo
Old Apr 27, 2004 | 05:50 PM
kevo2k6's Avatar
Car: 1990 Camaro RS
Engine: 3.1L v6
Transmission: 700r4 auto
Turbo
wut would be a good turbo to throw on the 3.1L v6? im lookin at turbos on ebay im think like a t25 but wut would u guys suggest?
Old Apr 27, 2004 | 08:42 PM
vortex's Avatar
Car: 95 Mustang GT Vert
Engine: 5.0
would i be good cop or bad cop if i just said.. digga, a digga digga ....
https://www.thirdgen.org/techbb2/sho...hreadid=231396
https://www.thirdgen.org/techbb2/sho...hreadid=183553
Old Apr 27, 2004 | 09:00 PM
RedTtop5spd's Avatar
Car: 99 SS
You'd be both at the same time.
Do a lot of research before starting this project. Best of luck.
Old Apr 28, 2004 | 02:16 AM
oil pan 4's Avatar
Car: 89 Firebird
I think T25's are to small, if I rebmer right there only good for about 250hp.
Any one have a link to a compressor map?
Old Apr 28, 2004 | 09:36 PM
kevo2k6's Avatar
Car: 1990 Camaro RS
Engine: 3.1L v6
is a t3 bigger or smaller than the t25?
Old Apr 29, 2004 | 02:04 PM
90firebird's Avatar
Car: Base Firebird
Engine: TPI 350
Axle/Gears: D44
good luck on the project....
also, seeing you're from california like i am, good luck smogging it and getting it registered...
Old Apr 29, 2004 | 06:51 PM
kevo2k6's Avatar
Car: 1990 Camaro RS
Engine: 3.1L v6
yea smog will really suck doubt ill pass. ive got sum connections though for the underground stuff. wut part of cali u in?
Old Apr 29, 2004 | 07:13 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
if you have a buddy that is willing to pass your car with a mod like that, then he is probably willing to do it for others as well. That means that the BAR will be on his **** faster than you can say turbo, he'll lose his liscence, and then what? The best luck that we Californians have is to either wait until someone comes out with a CARB approved turbo kit for us or to do a COMPLETE swap from a currently smog-able vehicle and get the referee to give you a BAR Label for it. Good luck on that though.
Old Apr 29, 2004 | 07:49 PM
90firebird's Avatar
Car: Base Firebird
Engine: TPI 350
Axle/Gears: D44
^^ well said... thats pretty much the gist of the situation...
i'm in Long Beach, btw
Old May 9, 2004 | 03:45 AM
ScrapMaker's Avatar
Car: 2000 Trans Am WS6 (Black)
seems like california is too liberal... come to texas where you can drive anything with wheels
if the guy inspecting your car likes it, he will most likely just check your bulbs and let you go... the guy i got didn't even do that...
Old May 10, 2004 | 01:39 AM
90firebird's Avatar
Car: Base Firebird
Engine: TPI 350
Axle/Gears: D44
yeah... damn california emission *****...
Old May 10, 2004 | 04:33 AM
oil pan 4's Avatar
Car: 89 Firebird
T61
Over on the camarov6.com tango used a T04B
@15psi he got
336rwhp
400rwtq about
He changed the turbo and his turbo piping some with the T61
@5psi
290rwhp
400rwtq, all most
It looks like the bigger turbo is better in our case.
My advice, cut and run.
Move to Tx or NewMexico, all most any thing goes and say good by to $4 a gallon gas prices.
If my next base is in Ca I'll be screwed, my cars most of my guns what armor pearcing & tracer rounds I have will be illigal.
It will be just japan all most. I won't beable to have any of my cool stuff just like over here.
Old May 10, 2004 | 09:45 AM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Just a reference -
T04B s trim (What he was running @ 15psi) = 525 cfm @ 14.7psi
16G Small Wheel = 520 cfm @ 14.7psi
16G upgraded, clipped, ported = 550 cfm @ 14.7psi
I'll be running a slightly bigger turbo, on a slightly smaller motor, with a slightly bigger intercooler, and should have more adiabatic pumping efficiency, since the 525 cfm of the T04B is @ 50% efficiency, vs MHI's 550 on the 60% efficiency line...
What's this mean?
15psi should actually build more power on my 3.1/16G, than Tiago's T04B/3.4.
But hey, theory is all well in good. We'll see what ACTUALLY happens.
Wish us luck!
Old May 10, 2004 | 10:31 PM
ScrapMaker's Avatar
I still want to make a blower out of my smog pump
Old May 10, 2004 | 10:38 PM
vortex's Avatar
Engine: 5.0
been thought of before.. a number of issues that made it not feasible.. (1) pulley size, wouldnt produce air worth a damn, (2) air pushed out of an S/P is far less than what an engine can run on, so you would have to have a cold air induction with that plumbed in to keep your engine from choking out.. and (3) one of the most important aspects is that a supercharger uses impellers to spin the air inside and compress the air (hence the heat and need for an I/C), a smog pump is just that.. air in air out.. basically a valve with a pulley. no compression..
not trying to sound like a smart ***, its just youd have to build the guts of an air pump and the cost of fabrication would most likely be more than the cost of just a supercharger head unit.
Old May 11, 2004 | 06:49 AM
oil pan 4's Avatar
Car: 89 Firebird
Our v6 engine is not a blower engine at all. The intake is to restrictive, blower engines need a good intake side.
It would make a great nitrous engine if any thing, because of it's good exhaust flow.
Old May 11, 2004 | 07:04 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
I've heard of people using their smog pumps & converting them to air pumps. Might want to go in that direction.
Old May 11, 2004 | 06:28 PM
Doward's Avatar
Originally posted by oil pan 4
... it's good exhaust flow.
This is news to me!
Old May 11, 2004 | 06:52 PM
br()bert's Avatar
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
I guess he hasnt taken a good look at the stock exhaust manifolds ?
Old May 11, 2004 | 07:14 PM
vortex's Avatar
Engine: 5.0
I have... its the equivalent to a 500 lb man running a marathon... breathing only thru a straw...... ..... a straw with a potato stuck in it.
oh.. and your t-pipes dont help none...
Old May 11, 2004 | 07:41 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
yea, our manifolds suck.........
er blow.......
you know what I mean
Old May 11, 2004 | 07:56 PM
br()bert's Avatar
Car: 85 firebird
LMFAO
So whats the best guess the headders will add?
Old May 11, 2004 | 08:00 PM
vortex's Avatar
Engine: 5.0
well i have a WIP on a different set.. something a little more functional.. usually a header swap is good for at least 5-10ish right? im guessing a smidge more if bolted on at the same time as a VP turbo kit.
seriously tho, i need a few more paychecks before i can get the plasma and get thru the metal the way i want.. also i got a new project 4x4 in the works... so its bleeding impossible to get anything done so stretched out.
***** on your forehead
Old May 11, 2004 | 08:48 PM
Doward's Avatar
??? WHEN THE HELL DID YOU GET THAT PIC OF ME!!??
so much time... so little beer., :lala:
Old May 11, 2004 | 10:16 PM
oil pan 4's Avatar
Car: 89 Firebird
My pipes...
javascript:ShowImage
http://www.cardomain.com/member_page...76_22_full.jpg', 575, 461);
These should flow ok.
Old May 11, 2004 | 10:20 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
and sound like absolute butt....
(did i say that out loud?)
Old May 11, 2004 | 10:27 PM
br()bert's Avatar
Car: 85 firebird
:werd: Id like to see the tq numbers with those.
Old May 12, 2004 | 12:27 AM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
.... I gotta agree with 'em. That's not going to sound pretty (personal experience). At least they're flowing the right direction, though. A+ for the road less traveled
One question.. what diameter are those pipes? They look about 1/2" too large.
Old May 12, 2004 | 03:19 AM
oil pan 4's Avatar
Car: 89 Firebird
The pipes are 1 3/8'' SS, pre bent, the bolt holes line up perfectly and I found a hole pile of them, they were used on a diesel engines and are several years old and have no rust on them.
There the main part of my turbo manifold. Now all I need is the measurements, more Argon, and some .025'' 309L or better mig wire. I will have full SS turbo manifolds.
Back home I had ported non EGR manifolds on the old 2.8 I don't know if they helped any because the last "new engine" turned out to be a peace of crap that lasted 400 miles.
Old May 12, 2004 | 07:10 AM
Doward's Avatar
Yep... just a bit more time, then we'll see how our own creation flows.
Doward's Avatar
Old May 12, 2004 | 07:57 AM
Car: 99 SS
Wow...that's really looking nice.
Old May 12, 2004 | 08:03 AM
Doward's Avatar
Thanks... we're doing this for us - the V6ers with the 'puny' engines!
Old May 12, 2004 | 09:19 AM
Car: 99 SS
Well, I just ordered my new clutch, and, as stated in another post, I'm not doing my own turbo setup anymore. So, get it done and you're likely to get another buyer.
Old May 12, 2004 | 11:00 AM
br()bert's Avatar
Car: 85 firebird
I can see this being brought up for some time now.
Old May 12, 2004 | 11:59 AM
TechSmurf's Avatar
Engine: LS1, Scrap
Weird.. they look bigger in the pic. *shrug* perfect stuff. Should be interesting to see what it looks like when yer done
Old May 12, 2004 | 12:33 PM
Doward's Avatar
No hard feelings, man. I can't begin to count the number of times V8 guys (mostly 4th gen, actually) have laughed since I started this project. Just a little more, and we'll see who laughs last!
RedTTop, not a problem. Like V said, we're currently working on a set of headers, as well - but while these may not have the CARB number of the Pacesetters, our goal is to exceed their performance. After all, we're not worried about street legal - we're worried about race only
Also, just in case anyone is wondering, the headers V is working on, can be used with our turbo kit, or N/A - Yes, that means you can get a set of headers, enjoy the benefits, and then get the turbo kit later - AND YOU'LL ALREADY HAVE HEADERS THAT WILL WORK WITH IT! Pretty cool, eh? I've always loved interchangeability (Thank you, Poncho Gods!)
Oil pan, that's stainless steel? I thought SS was shiney? Or are they just really dirty?
Old May 13, 2004 | 07:07 AM
oil pan 4's Avatar
Car: 89 Firebird
There old, they came with diesel soot in them and most have rtv on them. I don't think they were ever shinny.
They have no trace of rust, good for some thing that has been on a diesel engine for years in a place that rains all the time.
There 1 3/8'' I.D.
And I have 2.5'' down pipes for the turbos there from the stock 1.8T beetle, also SS. There just about the same color and texture of the 1 3/8'' header pipes.
Old May 16, 2004 | 09:37 AM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
**** 'em. Your project isn't something I'd take the time and $$ to do but it's YOUR time and $$$. If you're willing to spend it on a project like this and it makes you happy that's all that matters
Old May 17, 2004 | 01:07 PM
ScrapMaker's Avatar
any word on how much the headers alone will cost at first?
Old May 17, 2004 | 09:04 PM
Doward's Avatar
I'm thinking $299, coated.
We'll see as that progresses... it's in Vortex's hands right now - he's building a custom collector for it.
Old May 17, 2004 | 10:40 PM
  #42
Pillsbry10's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
would it be hard to adapt it to a set of headers i already have on my car?
i cant wait for you all to get done with this, you can count me in thats for sure
Old May 18, 2004 | 08:23 AM
  #43
Doward's Avatar
Depends on how your current headers are set up.... I *might* be able to adapt the turbo kit to the pacesetter headers, but until I can actually get a set, I won't know...
Old May 18, 2004 | 12:33 PM
  #44
Pillsbry10's Avatar
well i have the PF@E headers.... http://www.deadbird.org/swin/index.php?showtopic=8
there are plenty of pics of the install on there, what do ya think?
Old May 18, 2004 | 04:34 PM
  #45
Doward's Avatar
If I were to get a set of the PF&E headers, it wouldn't be too hard to make them work with the turbo kit. Problem is, how many PF&E headers are out there for the V6?
Old May 18, 2004 | 10:16 PM
  #46
Pillsbry10's Avatar
hmm...yeah this is true, i think im the only member still on the board that has them. ill have to look at the setup you use and see if i cant fab somethign up to make it work. maybe ill road trip to flordia and see what you can do lol
Old May 18, 2004 | 10:20 PM
  #47
vortex's Avatar
Engine: 5.0
ok... i just gotta step in here for a minute...
ok.. im done.. later...
oh, and we're gonna have some new toys soon.. just hang on the hook a little longer... got a few tricks up the sleeves of the new VP tank tops on sale $10.99 US.
Old May 18, 2004 | 10:23 PM
  #48
Pillsbry10's Avatar
hahaha o o count me in on the Tank Top!!!
Old May 18, 2004 | 10:25 PM
  #49
vortex's Avatar
Engine: 5.0
unholy Sh*t doughboy, you just wanna invest in VP now don't ya... Im wondering if we might just give a kit at cost to those who donate to the fund... :-)
Old May 18, 2004 | 10:28 PM
  #50
Pillsbry10's Avatar
hahaha now theres an idea
