Not a comforting sight
Old May 1, 2004 | 11:52 PM
RedTtop5spd's Avatar
Car: 99 SS
This is what I found going out to my camaro this morning. Doesn't make you feel very comfortable. Anyone know how to get the window crank off an 85? This is the only thing I wasn't able to get off so I could replace the locking cylinder.
Old May 1, 2004 | 11:57 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
window crank off the inside? easiest is a special tool that costs like $5 or so. I have used needle nose pliers on other cars in the pst, but get the tool, much better & easier
Old May 1, 2004 | 11:59 PM
Car: 99 SS
Where and what part number?
Old May 2, 2004 | 12:01 AM
Engine: 5.7 / 7.4
auto parts stores. I think it's just called a window crank removal tool
Old May 2, 2004 | 12:25 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: Not a comforting sight
Need some sort of alarm warning. I have dumb stickers but only a smart theif know to hit the pre 87 I think. after 87 they installs the vatts system casue these cars were stolen so often and so easy.
I have lots of bright lights. walmart sells a light by lights of amercia. uses 45 watts and puts out 200watts $8-10. its like 400 really. makes it day time out side.
I just work around the crank.You can get everything lose enough to just spin the whole works out of the way. You shouldn't need much room anyways. I had to put in a lock clip on my rod and it was easy to get at the lock cyl.
Old May 2, 2004 | 09:34 PM
Car: 99 SS
Hey, thanks for the help. I'm going to be shaving the handles in the future, but that won't happen until I replace the driver's side door. I'll be putting a simple alarm on at the same time as well. I'll try doing it without removing the crank. I can't see a clip anywhere.
ALIENhumanoid
Members Camaros
80
Apr 23, 2016 11:35 PM
blackz281le
Jan 11, 2016 07:51 AM
S10K20
Oct 7, 2015 06:45 PM
Briandrex
Oct 5, 2015 06:20 AM
ndndndnd
Sep 28, 2015 08:00 AM
