Marvel Mystry Oil
Old May 7, 2004 | 08:05 PM
camaro350man's Avatar
Car: 1988 Pontiac Firebird
Engine: 2.8 Lt
Transmission: 5 Spd
Marvel Mystry Oil
I bought some of this and pan on putting it in my car. it says to mix 4-8 ounces every quart of oil. Is that right? Seems alot to me? That would be like a quart of MMO in my car. Is that alright?
Old May 7, 2004 | 08:13 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
1QT MMO 4 QTS oil.
The stuff works good i would actualy run it before you do an oil change for a few hundred miles then do the oil change and put it in.
FYI a 5 Quart bottle of it is 9.00 at Wal-Mart
I also like there 5 QT Mobil 1 oil that i use in my 3.5 altima 20.94 a jug
Old May 7, 2004 | 08:43 PM
Engine: 2.8 Lt
Transmission: 5 Spd
But i can't add it now, i have oil right where it should be, it will over fill it if i put it in. You were very happy with it. What did you notice?
Old May 7, 2004 | 09:07 PM
FAST RS's Avatar
My oil PSI went way up at first for about a 1000 miles then i did an oil change. It was still at around 80PSI then after about another 1000 miles it went down to where it used to be just a little bit higher. I think it got rid of all the sludge and stuff in my engine. It also made the lifters quieter. I still havent tried it in the fuel tank.
Old May 7, 2004 | 09:22 PM
Engine: 2.8 Lt
Transmission: 5 Spd
Alright. I will change my oil tomorrow and then go from there. You can't mix engine restore with that can you? You think that works? So the MMO cleans and lubs the motor? Thanks
Old May 7, 2004 | 09:27 PM
FAST RS's Avatar
I would jsut use MMO i dont think its good to put tons of additives in. I do however use duralube once a year that also helps with engine noise.
Old May 7, 2004 | 10:17 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
It's still a bandaid for your problem. You should try running the proper weight oil first before you run the MMO. If the bearings and seals are alright, you won't need any additives in the oil, and running with additives is not recommended.
Old May 8, 2004 | 12:00 AM
br()bert's Avatar
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
MMO isnt a bandaid, its cleans the inside pretty good. I had a collapsed lifter for about a month, i put some mmo in, drove 5 miles and the lifter was fine again. I dont think the mmo has anything to do with putting the proper weight oil in at all.
Old May 8, 2004 | 05:55 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Well I still say he should try running 10W-30 instead of 5W-30 first, unless he plans on rebuilding soon...
Old May 8, 2004 | 05:57 PM
br()bert's Avatar
Car: 85 firebird
yeah i would agree on the 10 30
Old May 8, 2004 | 05:58 PM
Engine: 2.8 Lt
Transmission: 5 Spd
This stuff could screw up my motor?
Old May 8, 2004 | 05:59 PM
FAST RS's Avatar
I totaly agree with that i run 10-40 in my car 5-30 is too thin especialy in the summertime witht the heat.
Old May 8, 2004 | 06:00 PM
br()bert's Avatar
Car: 85 firebird
MMO no it wont, but 5 30 is pretty thin, then it gets hot and gets thinner, mostly everyone runs at least 10 30
FAST RS's Avatar
It wont screw up your motor i have 230,000 mile son my engine if it was gonna screw it up it would have by now. You have nothign to worry about.
jrdturbo
Mar 31, 2016 02:58 PM
skinny z
Oct 5, 2015 06:23 PM
meeklay812
Oct 1, 2015 03:46 PM
Gordonr1973
Sep 29, 2015 11:59 AM
