some things not connected
Old May 7, 2004 | 08:39 PM
FirebirdNYC's Avatar
Car: 1990 firebird
Engine: 3.1 v6
so here are some more pics of stuff that is not connected in my car, can anyone let me know where these things belong, my previous owner seemed to have fun with disconnecting things and leaving them hanging around... here are the pics.. any help apreciated , , second is by all the relays on the right side of the engine bay
90 firebird 3.1
Old May 8, 2004 | 05:47 AM
ede's Avatar
ede
the plugs may be for things your car deosn't have. it wouldn't be odd for gm to make a change in the engine sensers but not change a harness or use up all the old harnesses before going to the new wiring. shouldn't be hard to find where they go since the wire is only so long and would have to reach whatever it plugs into.
Old May 8, 2004 | 10:57 AM
92RSSlowmaro's Avatar
I went out and peeked under my hood to get a better idea of what you were talking about, but I didnt see any connectors like that. Like ede said, they may be for components that arent on your vehicle. Im assuming your not getting an SES light? I wouldnt really worry about it.
Old May 8, 2004 | 06:40 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
That first connector doesn't look familiar at all.......but it might go down to the smog pump (under the alternator).
That second one *might* be the fuel pump test wire.......what relay is that coming from??
Old May 9, 2004 | 02:12 AM
Car: 1990 firebird
Engine: 3.1 v6
i cant find anywhere to plug the first one in to...the second one it doesnt come from a relay it comes from the harness, the plug just sticks out
as far as the ses light, i get a code 32 , im going to check around the alternator to see if there is any plug
Old May 9, 2004 | 12:09 PM
Isnt code 32 Barometric pressure sensor? Or EGR or something like that?
Hang on, lemme go look at my car again...
Old May 9, 2004 | 12:32 PM
Car: 1990 firebird
Engine: 3.1 v6
no its the egr one ,
i apreciate those who are going back to there car to take a look
Old May 9, 2004 | 12:53 PM
Well, im not seeing this connector.
Given what we know about it, (Nothing at the moment) and the fact that our engine bays are layed out differently, its damn near impossible for me to judge.
Hopefully someone with a bird can take a look and see if they can find it.
Old May 9, 2004 | 04:50 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I haven't seen either of those on my '86...
Old May 9, 2004 | 05:03 PM
BitchinRS's Avatar
The single wire to the right side of the engine bay is just a test wire. No need to hook it up to any thing. The other one has me stumped. Could you get a little wider angle shoot of it? Being able to see more of what is around it might make it easier to figure out.
Old May 9, 2004 | 07:16 PM
Car: 1990 firebird
Engine: 3.1 v6
as for now i cant take a pic since its dark outside, im going to do some photoshopping to a pic i have of my engine and let you guys know where its located, hopefully that helps, tomorrow i'll def take pics of it
Old May 9, 2004 | 09:04 PM
BitchinRS's Avatar
OK studied the pic a little more and figure out what area I was looking at. Unforthunetly I could find a similar one on my car, do the '90 birds use a vaccum type EGR or the digital EGR? If it uses the vaccum type does it plug into it or the controll soliond (SP?)?\
Old May 9, 2004 | 09:06 PM
Engine: LH0 3.1L
There's a solenoid on the back of the smog pump underneath the alternator. See if its hooked up. If it's not, that 2 wire connector might go to it. I'm too lazy to go look at mine.
Don't worry about the single wire connector though.
EDIT: BitchinRS, the 90-92 uses the digital EGR valve with a triangular shaped 4-wire connector.
Old May 10, 2004 | 11:53 AM
Car: 1990 firebird
Engine: 3.1 v6
hm im going to take a look today, the plug does seem to run under the alternator but then i loose the wire, im going to see if i can trace it
Old May 10, 2004 | 05:25 PM
Car: 1990 firebird
Engine: 3.1 v6
okay so i took another pic, correct me if im wrong but i think my car doesnt use a solenoid, i heard this on the board and my haynes book , 90 firebird 3.1, if my car doesnt use a solenoid im guessing its one of those things that pontiac put on the engine in case it did come with the solenoid it would be connected if it didnt it would just be there.. am i wrong
Old May 10, 2004 | 10:09 PM
Engine: LH0 3.1L
Yeah, that goes to the smog pump. That picture confirms it.
The solenoid is mounted BEHIND the pump where you can't see it. You might even have to have to remove the pump but it's not hard at all. 10 minutes tops.
BTW, the smog pump is what's in the very bottom left corner of that picture.
Old May 10, 2004 | 10:31 PM
BitchinRS's Avatar
No you don't have the EGR controll solenoid. As CaliCamaroRS pointed out you have the digital EGR. I knew the '92 had the digital EGR but wasn't sure what year they started useing them.
Old May 10, 2004 | 10:40 PM
Car: 1990 firebird
Engine: 3.1 v6
im confused calicamarors so do i plug it in the solenoid , bitchinrs just said i dont have one, which im sure i dont....guys?
Old May 10, 2004 | 11:21 PM
Engine: LH0 3.1L
He's talking about the EGR. I'm talking about the SOLENOID ON THE BACK OF THE AIR INJECTION PUMP UNDERNEATH THE ALTERNATOR.
Old May 10, 2004 | 11:37 PM
Car: 1990 firebird
Engine: 3.1 v6
oh now i understand you, cool thanks alot , you said its easy to get to... im going to see what i can do, i dont want to start taking things apart without knowing how to put them back, any suggestions...tools etc... steps would be nice..i apreciate the effort guys
Old May 11, 2004 | 08:35 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Hey man in that last picture I see some antifreeze (radioactive green color in the picture) underneath your upper radiator hose; is your thermostat housing leaking?
(The only fluid I hate worse than antifreeze is super-dirty-brown antifreeze.)
Old May 11, 2004 | 08:42 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Yes, thats smog pump plug.
Red wire is I belive a test jumper wire for the fuel pump. Just tape it up and tuck back into the harness.
Old May 11, 2004 | 05:41 PM
Car: 1990 firebird
Engine: 3.1 v6
TomP yeh i believe it is but i just got me engine clean today so it will be easier to check if something is leaking,
Let me check my haynes book to see if i see anything about the air pump, and how i can go about plugging that wire in... i cant seem to find it but like calicamaro said i have to take some stuff off to get to it
Old May 12, 2004 | 10:37 PM
Car: 1990 firebird
Engine: 3.1 v6
well since i cant seem to find the plug on the smog pump im going to have take it out to see if i see anything behind it . anybody got any ideas before i tear **** apart
BRoss99
Aug 10, 2025 05:08 PM
eightsixseven
Dec 16, 2024 01:50 PM
Reborn756
Sep 4, 2015 03:42 AM
Bob88GTA
Aug 18, 2015 03:31 PM
Bull86
Aug 10, 2015 05:43 PM
