Steering
Old May 14, 2004 | 01:03 PM
6cyl92CamaroRS's Avatar
Car: 92 Camaro RS
Engine: 3.1 L
Steering
When I'm parking and i turn all the way to the left or right the car makes a really weird creeking noise and i can feel it in the steering wheel. It just does a really loud creeking noise for a couple seconds right when i turn it all the way and then stops, any idea what that is?
Old May 16, 2004 | 10:02 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
A creak? Hmm....cracked steering box perhaps?
Old May 16, 2004 | 11:12 PM
yellowmaro's Avatar
Car: 1986 Camaro SC
Engine: 2.8, headers, duals
Transmission: auto, 125 speedo, accel coil, k & n
I had same problem with hard turns. It was lower ball joints. The 3rd gen do not have upper ball joints. However, if you tear in to replace, take a good look at tie rods, struts, end links, springs, and bushings. I replaced my struts(bad), tie rods, and balljoints(bad) and now I think my upper struts bearing on driver's side is bad as front end makes noises as before replacement, no sounds at all. Bottom line, if you tear in, examine hard aqnd replace all instead of having to go in again and (hopefully not), a third or fourth time.
Old May 17, 2004 | 09:07 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
sure it's not just the power steering? Yeah it may be too obvious, but sometimes the easy things get overlooked.
Old May 17, 2004 | 09:37 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Had a similar noise; turned out the passenger side's upper strut mount was shot- the bearing was gone. It kinda melted itself into a bushing. I replaced everything (and I mean everything) related to the front suspension at the same time.
6cyl92, how often do you do lube jobs?
Old May 17, 2004 | 10:18 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Someone in the suspension forum noticed that 3 of 6 bolts holding the "subframe" in was missing. Might want to check that.
Rag joint in steering shaft dry rotted?
Control arm bushings bad?
Old May 22, 2004 | 11:01 AM
92RSSlowmaro's Avatar
Ball joint.
With the car jacked up, lower it onto jackstands placed underneath the lower control arms. Physically inspect the boot on the ball joint. Then you can place a pry bar under the tire and try to lift up on it. If it moves, your ball joint is shot.
Old May 22, 2004 | 12:20 PM
GreyFox's Avatar
Car: 1991 Firebird
Engine: V6
Transmission: ATOD
try fluid level or the belt tension, may need a new one, sounds simple enough
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
loud91rs
Oct 5, 2015 10:05 PM
sjorgens
Oct 1, 2015 07:54 PM
Night rider327
Sep 25, 2015 04:19 AM
