i thought everything was ok
Old May 23, 2004 | 12:22 AM
mory's Avatar
Car: 89 camaro
Engine: 2.8L V6
my cars idle slightly goes up and down somtimes while stopped. it does this somtimes very slightly and i can see my rpms go up & down from 500 to 550 slightly and stop. whats going on with the car? is it a vacum leak some where? does somthing need 2 be ajusted?(new TPS,fuel pump,fuel filter,o2,intake sealed,new vacum lines,presure reg and injectors).
Old May 23, 2004 | 12:44 AM
92RSSlowmaro's Avatar
Slighty erratic idle can sometimes be caused by a faulty PCV valve...
other than that, im not completely sure. Maybe your timing is a little off?
Old May 23, 2004 | 12:18 PM
BitchinRS's Avatar
Either it's a missfire or a vac leak. This is how I tell I need to do a tune up.
Old May 23, 2004 | 09:16 PM
Red1992V6Rs's Avatar
Car: 1992 RS
Engine: 3.1
me too
i have this problem too...i was going to post but good thing i read it....mine jumps up to 700 rpm and back down to 500rpms
Old May 23, 2004 | 11:22 PM
mory's Avatar
Car: 89 camaro
Engine: 2.8L V6
yeah i fogot 2 add that i also changed the PCV last week. this guy told me he did my timing but i think he was a lie. i was also thinking it was the timing. i can see also my battery voltage thing move up and down along with my RPMs. im confussed As 4 red1992v6, u may have a problem with a leaking intake. i just bougt intake mainifold gaskets and resealed them. my car was doing the same thing.
Elephantismo
Feb 13, 2019 12:51 AM
David Frans
Oct 31, 2015 08:12 PM
tmellott89
Oct 14, 2015 02:06 PM
Damon
Sep 26, 2015 04:29 PM
IROCZ1989
Sep 4, 2015 11:54 AM
