Engine Cleaning???
Old May 23, 2004 | 06:46 PM
knight75's Avatar
Car: 1987 Pontiac T/A with Knight Rider conversion
Engine: 2.8 V6
Transmission: 700r4?
Engine Cleaning???
Just wondering what you guys would recommend to get my 2.8 engine cleaned up. I know for one thing I need to replace my valve cover gaskets and oil pan gasket or else it wont be worth cleaning. I really just want to dress the engine compartment up after cleaning. I have a set of chrome valve covers I want to put on it.
Thanks!
Knight75
Old May 23, 2004 | 08:58 PM
br()bert's Avatar
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
oven cleaner
Old May 24, 2004 | 03:20 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Do this when the engine is cold! Put a garbage bag over and around your alternator; wrap it up tight (remember the engine's gotta be cold or you'll have one hell of a mess). Cover the distributor cap with tinfoil, and cover anything else electrical that you can see with the tinfoil.
Try not to get any cleaner on the paint! If you do, rinse and rinse and rinse the cleaner away; if you try to rub it away with a cloth, you may rub that spot of paint away!
After you clean your motor and hose it off, remove the plastic bag from the alternator and ALL tinfoil. Lower the hood (but don't latch it) and start up the motor. Wait a bit and then raise the hood so the steam can clear out.
If you just start the motor with the hood open, any engine cleaner left on your pullies and belt(s) will be thrown into the air, and could land on your paint, or in your eye.
Old May 24, 2004 | 04:07 PM
br()bert's Avatar
Car: 85 firebird
After Tom's post i reread the whole thread and my post was kinda, DUHHHH . Tom cleared it up though
Old May 24, 2004 | 04:15 PM
knight75's Avatar
Engine: 2.8 V6
Thanks Guys! Both of you
Knight75
Old May 24, 2004 | 04:56 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Heh, not really tho, I didn't tell him what to use. (Everything I listed was my own previous mistakes, by the way... except for covering the dist cap- that one I did correctly!)
I haven't cleaned my motor in, like, 5 years... it's not oily or greasy, just very dusty.
Old May 27, 2004 | 12:19 AM
85berlinetta2.8's Avatar
Car: IROC Z
Engine: 5.7
i like to do it when my motor is hot. i think the grease comes off easier that way. i use either simple green or that orange clean stuff. as it wont eat paint. i spray the engine heavily before i leave to go to the carspray wash booth, as i dont have a garage. when i get there i spray the engine again with the green or orange and use a 2 sided sponge to scrub at the bay. then i start the car and spray off the suds, and then spray the bay either with a can of non flammable wd40 (stinks and steams when on exhaust tho) or that tire black spray. works well imho
Old May 27, 2004 | 12:46 AM
92RSSlowmaro's Avatar
If you do it while the engine is hot, be ready to choke on a vast amount of steam.
Old May 27, 2004 | 12:26 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
And that plastic bag you put over the alternator will melt! Yuk. You can't really use tin foil because you'd short out the positive wire at the back of the alternator.
Old May 27, 2004 | 12:40 PM
Car: IROC Z
Engine: 5.7
cant remember the last time i did mine. could be better
Infested
May 22, 2018 11:56 PM
TheExaminer
Aug 26, 2015 04:59 PM
mdtoren
Aug 23, 2015 12:52 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
