Trunk and Starter
Old May 24, 2004 | 11:17 AM
6cyl92CamaroRS's Avatar
Car: 92 Camaro RS
Engine: 3.1 L
Trunk and Starter
The other day i went to my trunk and tried to open it and when i turned the key i could feel it catch like it usually does but it felt like the key just slid by and the trunk didnt open. I've been trying to open it for the past week and it's still not wokring. I dont have a release inside the car and i want to get this fixed what do you guys think it is and what can i do to fix it.
Also if when i try to start my car it just clicks a bunch of times does that mean i need a starter?
Mitchell
Old May 24, 2004 | 02:16 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
Sounds like a starter. The motor may have skipped a gear it sound slike it is working. If you disconnect the battary it will pop with out using the motor.
Old May 24, 2004 | 02:58 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
rapid clicking is usually either low battrey or cables are loose/corroded.
Old May 24, 2004 | 03:10 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Have you tried turning the hatch key while you pull up HARD on the hatch?
Old May 24, 2004 | 03:20 PM
Car: 92 Camaro RS
Engine: 3.1 L
The battery is at around where it usually is, and the car was istting for 7 tyears and just got fixed do you think that corroded wires would be whats wrong.
Yes i tried pulling up on it really hard and then i tried sittig on it while my girlfriend turned the key i tried everything with it...
Mitchell
Old May 24, 2004 | 03:37 PM
camaro_junkie's Avatar
Car: '86 Camaro SC, '16 QX60
Engine: 2.8 V6 POWER, 3.5L V6 N/A
Transmission: T-5, CVT
Originally posted by 6cyl92CamaroRS
...Yes i tried pulling up on it really hard and then i tried sittig on it while my girlfriend turned the key i tried everything with it...
Kinky!
Old May 24, 2004 | 10:28 PM
Car: 92 Camaro RS
Engine: 3.1 L
i know...
Old May 25, 2004 | 01:19 AM
coolrimsatleast's Avatar
Car: 89 f-bird and some others
Engine: 3.4
i'd check the battery cables and connections for tightness, if they're good use some jumper cables.
3rd gen money
Oct 11, 2019 09:57 PM
Gunner242
Dec 25, 2015 04:49 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
