biggest valves?
Old May 31, 2004 | 12:16 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
biggest valves?
i know you can get 1.8" intakes from supersix... how? the 1.72 and 1.42s are quite close to eachother as it is. i know that they say you can go 1.8 and 1.6 (?). does anyone have any of these heads or info they can give me. please no "you don't need it" or anything like that...anybody with real info? also, what's the best way to raise the floor in the ports? such as, welding or epoxy or what? thanks for any help.
Old May 31, 2004 | 08:32 PM
vsixtoy's Avatar
Car: '87 Cam RS V6
Engine: Top Secret
Transmission: DYT700R4 custom inerts and conv.
I have spoken to Tom at Supersix personaly. He has assured me the same worry I had about the room, I was concerned that the seats would crack- He said no, there is enough room to get the 1.8's in the intake comfortably. Exhaust valves stay 1.42", They are plenty large- Our problem is intake, not exhaust.
Welding is always best, but Epoxy has been done. I just dont trust epoxy coming loose over time, fuel soak, and heat.
Old May 31, 2004 | 10:53 PM
Car: 91 Camaro
cool, thanks. i might try it... i've got an extra set of heads that i can try it on. oh yea, got a seat grinder sitting out in the shed too!
Old Jun 1, 2004 | 06:48 AM
oil pan 4's Avatar
Car: 89 Firebird
You might want to try and put a bronze liner in the intake guide bore so you can use 5/16'' valve stems and get some near 1.8'' diameter valves.
That would help, I'm useing 5/16'' intake valves on my Z28's heads.
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
customblackbird
Oct 1, 2015 04:30 PM
355tpipickup
Sep 13, 2015 11:35 PM
sandman92084
Sep 12, 2015 10:27 PM
L0tuS
Sep 4, 2015 11:16 PM
