Intercooled Intake
Car: 1990 Camaro RS
Engine: 3.1L v6
Transmission: 700r4 auto
Intercooled Intake
has anyone ever tried intercooling your NON-turboed intake? if not will the intercooler not flow enough for the engine to suck in air?
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Interesting but a treuc cold air / ram air can do the same. It really hard to get it cooler than air temp. Though a car that suck hot uder hood air would see some lower temps.
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
from speculation:
I'd have to think that putting an intercooler on a non-turbo car MAY have the ability to cool the air. At the same time, i don't know how much, if any it would. With a turbocharged application, the air is radically heated with the compression process, and then cooled to enter the engine, however it's not ice cold air, just cooler than it was after the turbine.
I would also have to think that our engines could pull the air through the intercooler, or pull the air in the intercooler to the engine, however, the intercooler would most likely act as a restriction in the long run, making it more difficult to get the power you were hoping to, and at best, probably putting you in the same location you were already in.
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
think about how a air to air intercooler works.
the hotter compressed air inside conducts its heat to the alum.
the alum conducts it to the cooler air. at 100% efficency, the intercooler would make the compressed air inside the same as the air flowing across the outside.
but. if they are already the same temp, then nothign would happen.
except the intercooler will slowly warm up from the motor... and then it may actually add heat to the air.
not to mention, it will create a restriction....
overall, bad idea for a non boosted motor... unless you intend to cool the intercooler, it wont help. (if the intercooler was sprayed with a icewater mist or nitrous or some other gas that chills when sprayed, then it becomes effective..... but not as effective as if you just sprayed the nitrous INTO the motor.)
Car: 1990 Camaro RS
Engine: 3.1L v6
well it should be pretty cheap and easy to try im. and theres only one way to be sure if it works so im gunna try it this weekend. ill let you guys know how everything goes.
Car: 91 Camaro Vert
tornado is also cheap and easy. go try it.
geeze, do you guys ever bother to think about how and why somthing works before you go out and try it?
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
kevo, you do realize this is more likely to reduce power than increase, right? Intercoolers use ambient air to cool hot air blowing out of a compressor... without the compressor, if you're just sucking in ambient air to begin with, how do you think ambient air is going to cool ambient air? 90 degree air pushed through an intercooler being vented with 90 degree air is still 90 degree air... it's just 90 degree air that had to figure out how to get through an intercooler. Air from a turbo/supercharger can easily be 50+ degrees hotter than ambient air.. that's why intercoolers exist.
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
I agree with everyone, it's not going to do crap. Although...I saw an interesting thing on a new Mazda sedan at work. Naturally aspirated...but it had ram air, routed in a big circle around the motor, into an air to air intercooler that was also routed with a ram-duct to it, and back to the throttlebody. I scratched my head when I saw no turbo or anything... Completely absurd.
Or even better---those reusable ice packs you freeze and you used to put in your coolers when you were a kid at summer day camp... Or was that just me?
Lol but yeah......like it's actually worth it. Screw intercooling an N/A motor....
Car: 1990 Camaro RS
Engine: 3.1L v6
o ok thanks for lettin me know. but wouldnt routing my intake up to the front where an intercooler would be help. because i guarantee its better than the little air box we have. and wut about keepin the interocoler cooled like with water? or still a no?
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
anybody think about the weight you'd add? adding no power but adding weight will only slow you down.
Engine: LS1, Scrap
the 90-92 camaro air intake sucks, yes... best thing to do is replace it with the TPI-style dual snorkel if you want the closest to ambient you're going to get.
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Hmmm so it sucks in cold air that is then heated and the re-cooled.
well I'll just assume the ram air / cold air in the first part is just how it should be done and I will ignore that.
But I guess what they are doing is heating the air which would expand and raise the pressure? that is then cooled before being feed into the engine. The warm air would have hi pressure and the colder air would be lower. So it would have a small boost effect that would run well.
warm air expands and pushes against the cold air, which starts to cool but has more hot air coming.
Course this is all just a theory on why anyone would do that. Its the only effect I can think of. How valid it is
Car: 91 Camaro
toronto formula
Sep 10, 2015 07:31 AM
e3pres
Sep 9, 2015 01:51 PM
