engine knock
Old Jun 21, 2004 | 11:52 AM
Chris90Formula's Avatar
engine knock
I have a 2.8 in my '93 s10. I don't think the engine is exactly the same as the 2.8 in the f-bodies, but I was hoping someone here could help out. I'm getting knock during part throttle operations under load. But when I go full throttle it goes away. The engine is completely stock with 130,000 miles. I would have thought that the ecu would back off the timing until the knock went away. Could I be running lean? If so, what should I do? change the O2 sensor?
thanks,
Chris
Old Jun 21, 2004 | 04:06 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
sounds like spark knock to me. probably from a carbon build up on top of the pistons. get some GM top end cleaner and try that. from what i hear, its some good stuff.
Old Jun 22, 2004 | 07:43 AM
I'll look into the cleaner.
Is there a knock sensor on this engine? I'm wondering why the ecu doesn't correct it or throw a code.
Old Jun 22, 2004 | 10:42 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
The engine should have a knock sensor, but how do you have a '93 with a 2.8??? They switched over to the 4.3L in '91 for the S-Series truck.
The knock doesn't go away @ WOT, you just can't hear it. If you hear WOT knock, then you are damaging the motor. My money is on leaness. We see that all the time at the shop I work at. 99% of all the cars that come in and fail smog due to emisions, do it because they are running lean.
Old Jun 22, 2004 | 11:13 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Well there is rumors to be allot of Chevy truck that do not have the right 4.3 motor. Not sure where or who made them but I assume they ran short n stuck in anything that fit.
Buddy had a 91-92 from the original owner. It was also suppose to be a 4.3 truck but had a 3.4. The guy had paperwork to take it back to get the right engine but he never did. I changed the smog pump on that sucker. Its was a 3.4, should of been the 4.3
Old Jun 23, 2004 | 07:15 AM
The engine is definitely a 2.8 and its the original engine.
If it is running lean, how do I correct that? O2 sensor?
Old Jun 23, 2004 | 02:30 PM
camaro_junkie's Avatar
Car: '86 Camaro SC, '16 QX60
Engine: 2.8 V6 POWER, 3.5L V6 N/A
Transmission: T-5, CVT
I thought there wasn't a knock sensor on the 2.8?
edit: https://www.thirdgen.org/techbb2/sho...hreadid=244978
Old Jun 23, 2004 | 09:18 PM
Car: 1988 Camaro RS
Axle/Gears: 3.42's
The 2.8 that came in the S-Series truck was TBI, not MPFI, so it got a different computer. by 91, Gm "did away" with the 2.8 and went to the 3.1L. At that point, they were all Speed density(MAP) systems and had a knock sensor, the 2.8 didn't.
Old Jun 23, 2004 | 09:40 PM
Sounds good.
Old Jun 26, 2004 | 07:47 AM
Nocturnall's Avatar
Car: 91 Firebird
Engine: 191ci 6cyl
Where can you get GM Top End Cleaner? None of the stores around here have it...
Old Jun 26, 2004 | 04:23 PM
Car: 1988 Camaro RS
Axle/Gears: 3.42's
GM...
There is also a product made by a company named BG, we use their cleaner all the time, it works REALLY well.
Old Jun 30, 2004 | 06:10 PM
BlakBeard's Avatar
Hey if you want to clean carbon off of your pistons just floor that sucker and keep the revs up high, you'll burn it right off. I believe carbon buildup usually happens when you baby the motor and keep the revs down really low.
italiano67
Dec 11, 2016 09:21 AM
db057
Aug 22, 2015 08:17 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
gwade12
Aug 8, 2015 08:17 AM
