fuel pressure regulator
Old Jul 16, 2004 | 09:41 PM
Tim Hunsinger's Avatar
Car: 91 RS,
Engine: 406ci
Axle/Gears: 2.77 9 bolt
Raising fuel pressure on v-8 tpi cars seems to help performance, Will it have positive effects on a v-6 also? Are the regulators the same (v-8/v-6)?
Old Jul 16, 2004 | 10:35 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
regulator on the mpfi v6 is same as v8 tpi, yes.
Not sure anyone has actually given a yes/no response on just bumping up pressure on a stock 6
Old Jul 17, 2004 | 12:35 AM
FbodTrek's Avatar
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
On a stock motor it won't help, if you have a cam, hedders etc. THEN it is a good idea, keeps you from starving the motor of fuel high in the RPM.
Old Jul 17, 2004 | 01:03 AM
V6sucker's Avatar
Car: a car being parted out
Engine: blown up
Transmission: in peices
Or larger injectors, and reset the ECU. It will relearn the fuel curve and richen up automatically.
Old Jul 17, 2004 | 06:15 AM
Car: 91 RS,
Engine: 406ci
I read somewhere that SMALLER injectors (within reason) using higher pressure causes better atomization and more power. I've also seen graphs showing around 10 hp increase for a stock tpi 350. But then again, it may have been an advertisment for a regulator, I don't remember.
Old Jul 17, 2004 | 11:19 AM
V6sucker's Avatar
Engine: blown up
That's a solid theory yeas.
look at it like your using your water hose. What makes the water spray "out" futther, when the nose is full open? or when you have a portion of it blocked?
However, it can also cause fuel starvation problems by absolute lack of availible fuel. There is a fine line of having atomized fuel and fuel that is so atomized it can evaporate in the runners.
Old Jul 17, 2004 | 11:25 AM
vsixtoy's Avatar
Car: '87 Cam RS V6
Engine: Top Secret
Transmission: DYT700R4 custom inerts and conv.
Bumping up fuel pressure is not going to matter because the computer sensors are going to read rich and close down the pulse rate. So unless you have chip work done (prom) it isn't going to help.
I have a chip that fails the sensors at WOT and dumps the injectors at full capacity- in this case, it does help.
Old Jul 17, 2004 | 11:39 AM
V6sucker's Avatar
Engine: blown up
Thats why I said to reset the ECM with larger injectors.
Trust me, The motor richens up.
MustangBeater20
Oct 29, 2022 09:20 PM
9192camaro
16
Feb 3, 2019 12:21 AM
wayshegoes
Aug 17, 2015 12:00 PM
89-S-dime
Aug 12, 2015 11:57 AM
Kaweh
Aug 9, 2015 02:54 PM
