Stock coil replaced with Accel,MSD etc.?
Old Jul 25, 2004 | 04:24 PM
knight75's Avatar
Car: 1987 Pontiac T/A with Knight Rider conversion
Engine: 2.8 V6
Transmission: 700r4?
Hey I was wondering if any of you have replaced your stock coil with an accel or MSD coil. Which one did you go with and do you have pics. I'm putting the yellow Accel 8 mm wires and I want to replace my coil with accel and mount it to my firewall above the distributor.
Thanks guys!
Knight75
Old Jul 25, 2004 | 04:26 PM
V6sucker's Avatar
Car: a car being parted out
Engine: blown up
Transmission: in peices
the replacement goes right where the old one went.
You just have to drill the rivets, and buy some long screws and nuts.
Old Jul 25, 2004 | 05:39 PM
br()bert's Avatar
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
Or move the coil to a location with less heat. Like maybe the firewall .
Old Jul 25, 2004 | 07:53 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
I jus took a sharp edged wood scraper and hit the rivits with one good wack with a hammer they popped right on out. took 20 mins to take the old one out and bolt the new one in. Just make sure your engine is ice cold.
Old Jul 25, 2004 | 08:41 PM
MakeitQuick92RS's Avatar
Car: 1988 Pontiac Trans Am
Engine: 383 Stroker
Axle/Gears: Borg Warner 9-Bolt, with 3.42 Gears
My stock coil died and i immedeatly went to summitracing.com and got an MSD Blaster Coil. Works great! Ignition Module would also be a good investment if you plan on really working on the car. Both are easy installs and fairly cheap. In any case have fun with whatever you do to your car.
Old Jul 26, 2004 | 10:40 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I've put two coils in my car, neither were "direct replacements". My original one is still in it's factory spot as a "spare".
#1 was the "Accel remote HEI computerized supercoil", p/n 140008. http://store.summitracing.com/partde...art=ACC-140008 I made a bracket that mounted it between the top of the alternator and the top of the throttle body- it worked great for years.
#2 currently is the MSD Blaster SS coil. I bought it when I put in my MSD 6AL box; I wanted everything to be MSD. It's part number 8207. http://store.summitracing.com/partde...?part=MSD-8207 I made a bracket that's hung it off my a/c box. I used MSD's adapter # 8876, at http://store.summitracing.com/partde...?part=MSD-8876 , so I could plug my stock "spare" coil back in if I had to.
You can also use a $20 MSD Blaster 2 coil if you want to cut the factory harness wires.
Old Jul 26, 2004 | 10:52 PM
KED85's Avatar
My Accel coil set up Firebird
Using Accel 8.8 plug wires!
I LOVE ACCEL STUFF
Been using it for over 20 years.
Attached Thumbnails Stock coil replaced with Accel,MSD etc.?-3.4-20f-bird.jpg
Old Jul 26, 2004 | 10:59 PM
KED85's Avatar
My Accel coil on this Blazer, used since 1990 and has over 100,000 miles on it.
Never replaced.
Again Accel 8.8 plug wires.
I LOVE ACCEL STUFF!
ALL FIVE OF MY RIDES HAVE ACCEL STUFF on the engines.
Accel makes the greatest stuff!
AND those TWO SETS OF ACCEL 8.8 plug wires?
FREE!
I returned my older Accel plug wires and they upgraded to the BEST, the 8.8s.
LET ME REPEAT THAT
FREE!!! WARRANTY REPLACEMENTS!
Yet my Corvette does use the Accel 300+ 8.8 plug wires.
ACCEL MAKES THE GREATEST STUFF AND REALLY STANDS BEHIND LIFE TIME WARRANTY!
ONLY warranty item for me and my Accel stuff?
PLUG WIRE SETS!
Last set I paid for was back in early 1990's! The Accel Super Stocks.
After that all these other 8.8 spark plug wire sets, FREE!!!
Attached Thumbnails Stock coil replaced with Accel,MSD etc.?-belle3.4pass.jpg
9192camaro
16
Feb 3, 2019 12:21 AM
tazs2000
Jul 15, 2017 08:44 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
TheExaminer
Aug 25, 2015 07:34 PM
marcusaw
Aug 10, 2015 08:13 AM
