picked up new car
Old Jul 26, 2004 | 02:28 PM
mykxt202's Avatar
Car: 82 z28
Engine: 400ci 450hp
picked up new car
Hey I was just given an 84 camaro with a 2.8l and 700r tranny. The car has new frt fenders, hood , and nose.
The only problem is the engine has a bad knock.
My question is can I use any long block from a 2.8/3.1/3.4 and bolt up the intake from the 2.8 carb system? Also does it matter if the engine is from a RWD or FWD vehicle?
Any help would be appreciated. I just want to get something that runs then sell the car.
Old Jul 26, 2004 | 03:45 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
any 2.8, 3.1, or 3.4 from a RWD vehicle will work fine. and, yes, you can bolt the 2.8 intake stuff back on it.
Old Jul 26, 2004 | 03:51 PM
mykxt202's Avatar
Car: 82 z28
Engine: 400ci 450hp
So I'm not restricted to any particular years?
Don't I have to be concerned with Internal/External balance on the 2.8?
Old Jul 26, 2004 | 04:12 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Not if you use the flexplate from the V6 you're getting - and you can't use a FWD, btw.
Old Jul 26, 2004 | 04:15 PM
mykxt202's Avatar
Car: 82 z28
Engine: 400ci 450hp
So I'm looking for another 2.8 or a 3.4. Since the RWD 3.1 was only avail for a few years.
Old Jul 26, 2004 | 04:34 PM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
rwd 3.4 is just as rare... 3.1 == 90-92, 3.4 == 93-95 1/2... and both are F-body only.
Old Jul 26, 2004 | 04:35 PM
mykxt202's Avatar
Car: 82 z28
Engine: 400ci 450hp
What about the s-10's before they went to the 4.3?
Old Jul 26, 2004 | 05:20 PM
Car: 91 Camaro
the only other 6 cylinder (other than 4.3) available in the s-10s was the 2.8
Old Jul 26, 2004 | 05:22 PM
Doward's Avatar
2.8
Old Jul 26, 2004 | 05:34 PM
TechSmurf's Avatar
Engine: LS1, Scrap
Re: picked up new car
Originally posted by mykxt202
... 84 camaro ... 2.8l ... only problem is the engine has a bad knock.
Btw... 82-86 2.8s are rod chunkers... find an 87+ internally balanced large journal motor
The S-10 2.8 will work, however, it is a low output version. Try to stick to the F-body motors if at all possible.
Old Jul 26, 2004 | 08:27 PM
vsixtoy's Avatar
Car: '87 Cam RS V6
Engine: Top Secret
Transmission: DYT700R4 custom inerts and conv.
Re: Re: picked up new car
Otherwise known as 2.crap
Old Jul 26, 2004 | 09:50 PM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
3.4L should be pretty easy to find, while they're equally as rare, a 93-95 f-body isn't exactly a rare car to find...especially w/ a v6...get urself a 3.4L and buy the 4bbl intake, that lil thing will scream
Old Jul 27, 2004 | 11:07 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Actually (uh oh) only the 82-84's were small journal'd. 85 started the large-journal years, along with a one piece rear seal. But yes, 87-up is the most desirable because of the internal balancing- if you ever had to change the flywheel on an 82-86 with manual trans, you'd have to get the flywheel balanced to the crankshaft.
With 87-up, all you'd have to do is get the flywheel balanced by itself; much easier! That's the motor I'm going to try to rebuild for my car, an 87-89 2.8.
TS, if he put a MPFI f-body camshaft into an S10's 2.8, would it pick the power up? Or did the s10's get different heads?
Oh and mykxt202, the '84 700r4's also had problems. If you're going junkyard diving, if you go after an 87-up 2.8/3.1, see if you can get the guy to "throw in" the 700r4 for cheap. '87-up 700r4's are stronger than the 83-84 and 85-86 "series".
1983-1984 700r4's problems (off the top of my head, I think there's a few more)
- weaker input shaft
- porous accumulator pistons
- poor fluid pump design
1985-1986
+ stronger input shaft added
+ newer design accumulator pistons
- still a poor fluid pump design
1987
+ improved fluid pump design, 9 irregular vanes instead of 7 evenly spaced, prevents cavitation, prolongs trans life
+ addition of auxiliary valve body to cushion forward/reverse/forward rocking (car stuck in snow)
+ some other stuff
Not sure of what happened after '87, but generally, the newer the 700r4, the better GM made it.
Oh if you do get a 3.4, you can't use the 4L60E automatic trans that would be behind it.
Old Jul 27, 2004 | 11:18 AM
mykxt202's Avatar
Car: 82 z28
Engine: 400ci 450hp
Thanks you guys have given me lots of information
I don't think I'll be going the 3.4L way or changing the trans. I plan on putting an engine in it if its cost effective and selling the car. If it cost too much I'll just part out the entire car. I need the $$$ to update the suspension and brakes on my 82 z28
Steven 86IROC-Z
May 24, 2026 04:52 AM
Terrell351
Jun 13, 2021 01:13 PM
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
fonzie85
39
Mar 16, 2016 07:07 AM
camaro71633
Sep 1, 2015 10:24 AM
