Main Bearing Torque?
Old Aug 14, 2004 | 05:48 PM
Matt Finch's Avatar
Car: 1982 Trans Am
Transmission: Turbo 350
Axle/Gears: 3.23:1
I removed my main bearing cap on my 2.8 litre V6. I went to look in the Haynes manual for the torque specs and they were not there. How convenient!
Does anyone know what the torque spec is for a main bearing cap on a 2.8 litre V6.
Old Aug 14, 2004 | 07:37 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Main Bearing Torque?
The 3.1l v6 is 73 ft/lb. Most likely the same as the 2.8l. There is also an arrow on the cap that points to the front of the engine.
RBob.
Old Aug 15, 2004 | 08:05 AM
dream02transam's Avatar
Car: 89 firebird
Engine: 2.8
Transmission: auto
In my opinion Haynes aren't that great a manual, Chiltons is a little better and if you can get a Helms go for that but anyways according to my Chiltons the 2.8L main bearing cap torque is for an 1982-1984 = 74ft. lbs 1985-1989 = 83 ft. lbs. Never go by what some other engine is because they are not usually the same with the exception or some small block chevys
Old Aug 16, 2004 | 05:47 PM
Nocturnall's Avatar
Car: 91 Firebird
Engine: 191ci 6cyl
How good are Clymer manuals?
Old Aug 17, 2004 | 12:28 PM
Car: 89 firebird
Engine: 2.8
Transmission: auto
I have heard of the name but never hear much about them so I dont know how the Clymer manuals are.... anyone else delt with these?
Old Aug 17, 2004 | 01:21 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
GM updated all the torque specs as the 2.8 progressed to the 3.1
You can use the 3.1 Tq specs on the 2.8, because it is the same motor. It's got a different crank, and different pistons. Nothing more than a stroker 2.8
When I rebuilt my 2.8 with the 3.1 crank/pistons, I torqued everything by the latest GM specs I could find.
Old Aug 17, 2004 | 04:22 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
In my opinion Haynes aren't that great a manual, Chiltons is a little better and if you can get a Helms go for that (..snip..)
I'd never use a Haynes OR a Chilton for engine work- that's ridiculous. I'd use my Helms manual (http://www.helminc.com).
Old Aug 17, 2004 | 05:12 PM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
I've only seen Clymers for bikes... if I recall they're a Haynes subdivision... could be wrong, don't have one on hand.
Old Aug 17, 2004 | 05:17 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
damn thats an expensive book
but i guess a 3000 page shop manual for $117.00 american isn't bad
Old Aug 17, 2004 | 06:52 PM
Nocturnall's Avatar
Car: 91 Firebird
Engine: 191ci 6cyl
Techsmurf I was asking because I just got an old bike and only Clymers makes a manual for'em....I know it's not thirgen but I figured since we were talking manuals...
6speedIROC
16
Mar 15, 2023 08:33 PM
3GZJerry
LSX and LTX Parts
Oct 14, 2015 05:17 PM
customblackbird
Oct 1, 2015 04:30 PM
Nick McCardle
Sep 10, 2015 08:36 PM
