Vacuum at idle
Old Aug 28, 2004 | 07:29 PM
camaro_junkie's Avatar
Car: '86 Camaro SC, '16 QX60
Engine: 2.8 V6 POWER, 3.5L V6 N/A
Transmission: T-5, CVT
Vacuum at idle
What's the vacuum supposed to be at idle on the 2.8? I know it's been discussed before, but the search is not helping. Working on the car right now. Thanks guys.
Old Aug 28, 2004 | 08:25 PM
oil pan 4's Avatar
Car: 89 Firebird
You could have as much a 26'' of water.
If it is an older 2.8 you most likey don't.
Old Aug 28, 2004 | 09:01 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
If you're running 26 inches of WATER you're in trouble. What is a good vacuum pull is around 14-18 inches of MERCURY... AKA 14-18 in. Hg...
Old Aug 29, 2004 | 12:10 AM
vsixtoy's Avatar
Car: '87 Cam RS V6
Engine: Top Secret
Transmission: DYT700R4 custom inerts and conv.
Yep, most are about 17-18
Old Aug 29, 2004 | 12:52 AM
oil pan 4's Avatar
Car: 89 Firebird
There right.
This is why you should not fly half way around the world and start posting.
Old Aug 29, 2004 | 12:42 PM
Well, depending on where I hooked up to the engine I got 15.5-16.5 in-hg, rock steady. At the egr solenoid/decel valve I got 15.5, and directly off the manifold I got 16.5. Should I check for a vacuum leak, or is this good?
I also tested the tps voltage and got 0.51V which is within spec.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
IROCtometal
Sep 20, 2015 11:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
greenyone
Sep 8, 2015 08:41 PM
