low idle then dies
Old Aug 11, 2004 | 10:05 PM
kevo2k6's Avatar
Car: 1990 Camaro RS
Engine: 3.1L v6
Transmission: 700r4 auto
low idle then dies
today my friends car died so i went to give him a jump. we removed the batterey from my car and hooked it up to his because we were on the free way and could npt just jump it. wen i put the battery back on i coudlnt tighten it all the way so it was loose. wen i got home to turn the car off, right before i did the rpm needle tacked out but the engine didnt really rev. and then i shut it off. wen i turned it back on the idle was jumping between 1500 and 2000 rpms and then it drops down slowly to close to 500 rpms. i took it to the store and it died on me 3 times. it always happens wen i stop and the idle will drop all the way down and it just dies. is there sumthin to explain this?
Old Aug 11, 2004 | 11:49 PM
V6sucker's Avatar
Car: a car being parted out
Engine: blown up
Transmission: in peices
1. reset the ECM.
2. The third gens in my experiance have issues with large power drops, or having the battery removed while running.
It can make the electrical system go nuts.
Once you reset the ECM and have the battery back in CORRECTLY, the RPM shifts will stop.
Mine did this a few times, it is how I traced a bad engine ground.
Old Aug 12, 2004 | 10:20 PM
kevo2k6's Avatar
Car: 1990 Camaro RS
Engine: 3.1L v6
how do i reset the ECM?
Old Aug 12, 2004 | 10:40 PM
90ekm's Avatar
disconnect battery for 5 mins.
Old Aug 12, 2004 | 10:42 PM
kevo2k6's Avatar
Car: 1990 Camaro RS
Engine: 3.1L v6
while the car is running or off?
Old Aug 12, 2004 | 11:26 PM
90ekm's Avatar
car off.
Old Aug 12, 2004 | 11:34 PM
kevo2k6's Avatar
Car: 1990 Camaro RS
Engine: 3.1L v6
ok thank you very much.
Old Aug 16, 2004 | 10:37 PM
kevo2k6's Avatar
Car: 1990 Camaro RS
Engine: 3.1L v6
problem solved. thanks for the help. glad it was so easy to fix. but just to check wat schould it idle at in park and drive?
Old Aug 17, 2004 | 06:32 AM
V6sucker's Avatar
Engine: blown up
auto? 7-850 park little lower inD
Old Aug 17, 2004 | 09:45 PM
kevo2k6's Avatar
Car: 1990 Camaro RS
Engine: 3.1L v6
yea its auto, an its right there with what you said. thanks for the help.
Old Aug 17, 2004 | 10:11 PM
V6sucker's Avatar
Engine: blown up
that's what were here for
Old Aug 29, 2004 | 04:04 PM
legion7's Avatar
Car: firebird
Engine: 2.8 L
Transmission: MAnual
i nkow the problem
are you using unleaded?
use high octane gas to make it run better it will take a little while to get it working.
Old Aug 29, 2004 | 04:10 PM
br()bert's Avatar
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
Re: i nkow the problem
BTW i didnt know any gas stations had leaded gas anymore.
jklein337
Sep 19, 2018 06:23 PM
Andrew6.688
Dec 13, 2015 10:59 AM
bamaboy0323
Sep 3, 2015 06:07 AM
perZ
Aug 21, 2015 05:51 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
