3.1 V6 Rebuild...
Old Sep 15, 2004 | 12:06 AM
BushyTea's Avatar
Car: 1990 Camaro
Engine: 3.1 V6
3.1 V6 Rebuild...
Hey, just curious as to if anyone would know where to get a rebuild kit for the 3.1 liter v6 out of a 1990 Camaro.
Found one a few years ago but haven't been able to find one since then.
Old Sep 15, 2004 | 12:34 AM
FbodTrek's Avatar
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
Any major auto parts store Felpro makes a kit, melling makes a kit, speed pro makes a kit, Most major gasket/bearing companies for GM's make a kit.
Old Sep 15, 2004 | 06:18 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
https://www.thirdgen.org/techbb2/sho...hreadid=258824
Old Sep 15, 2004 | 11:25 AM
ljnowell's Avatar
www.northernautoparts.com
Old Sep 27, 2004 | 10:13 PM
StreetRoc85 350's Avatar
Car: 88 IROC
Transmission: Pro 5.0 shifted T56
Axle/Gears: 10 bolt 3.73 posi
Just ask for a rebuild kit when you take your block in for the machine work. Most any machine shop will have it. I had mine all apart last winter. Take my advice though, when you have it all torn apart kick in a few extra bucks and get the crane cam thats made for the 3.1. Its only like $140 out of Jegs. BIIIIG difference in my opinion. Ever seen a 3.1 chirp 3rd gear?
BTW- mine has a few other mods too, im not sure that just a cam will make yours chirp 3rd. its a good start though
Old Sep 28, 2004 | 10:25 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
which cam are you reffering to? crane makes about 8 cams for these engines... my cousing had a stock 92 3.1 camaro with a 5 speed that would chirp third. what all do you have done to your car, streetroc?
Old Sep 28, 2004 | 10:52 PM
vortex's Avatar
Car: 95 Mustang GT Vert
Engine: 5.0
ask doward... we did one for his car.. but i was just the designated beer drinker during the project... which is scary cuz im a real M.F'er (master fabricator)... i think the kit was from AZ i bought the sumbitch so im pretty sure we used his 20% discount... er... the crank kit may have been from carquest...but we have good connections here in SLOcala.. so i dunno.
Old Sep 30, 2004 | 12:02 AM
Car: 88 IROC
There are only 2 listed in jegs. i got the one thats for 1500-4500rpm. other than that its just minor stuff. a little mild headwork, 180* t-stat, TB coolant bypass, bumped up the fuel pressure a bit. its not really going to haul until im done with my next "project"
Smile if you like boost!
nd4spd42085
Feb 5, 2009 08:36 AM
ScrapMaker1
Jan 30, 2003 11:02 PM
