2.8-3.4 hypotech chip
Old Sep 15, 2004 | 03:47 PM
SCcamaro88's Avatar
Car: 88 camaro t-tops
Engine: 2.8-3.4 swap
Transmission: auto 700r4
i did a 2.8 swap and i was wondering if i can use the same chip in the 3.4???
Old Sep 18, 2004 | 12:23 AM
SCcamaro88's Avatar
can someone help please :hail:
Old Sep 18, 2004 | 12:39 AM
vsixtoy's Avatar
Car: '87 Cam RS V6
Engine: Top Secret
Transmission: DYT700R4 custom inerts and conv.
Its not going to hurt it.
It just may make it run slightly lean because the chip is calibrated for the 2.8 fuel pressure combined with 2.8 injectors. You may need larger injectors and the chip may run perfect or close enough to it- rarely are any chips perfect.
You just may not get the max benefit out of the motor.
Basically its not the chip to worry about, its the injector size that needs to be married to the larger displacement.
Old Sep 18, 2004 | 09:31 AM
SCcamaro88's Avatar
that sounds right lol thanks
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Gunner242
Dec 25, 2015 04:49 PM
KO1
16
Oct 15, 2015 05:00 PM
jaridjohn
Oct 5, 2015 07:01 AM
