the end of project "TB" is near
Old Sep 20, 2004 | 10:22 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
Throttle Body project is nearly done...
the new 65mm throttle body is basically done. i have a few minor things left to do to it. but, i had it on the car tonight and the engine idles right with it on there! :lala: i can just barely crack the throttle open with this TB on the stock manifold; the blade hits the front of the manifold. so, i gotta get the new manifold ne soon too!
Old Sep 20, 2004 | 10:23 PM
Car: 91 Camaro
here's another shot...that's as far as the blade will open.
Old Sep 20, 2004 | 11:40 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Where is that 65mm TB from?
Old Sep 21, 2004 | 03:19 AM
Car: 91 Camaro
that is the one that i built, from scratch.
Old Sep 21, 2004 | 05:50 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
so now a 58 or 60 should be easy right
Old Sep 21, 2004 | 08:14 AM
confucius101's Avatar
Am91 Great work man :hail:
please keep us updated
Old Sep 21, 2004 | 11:43 AM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Awesome work man!!
Old Sep 21, 2004 | 03:06 PM
Car: 91 Camaro
thanks, hopefully i'll have it on the car to stay before too long.
actually, the 58 or 60 could be more time consuming to make than this 65 was. however, i had to figure everything out for this one so IF i do more, they'll go together a little quicker. we'll see.
Old Sep 21, 2004 | 03:26 PM
Doward's Avatar
What would make it any longer than the 65?
Old Sep 21, 2004 | 03:30 PM
Car: 91 Camaro
i MIGHT end up with more time honing the bore, making sure it gets to the right size. i don't know yet, i'll have to explore a couple of other methods that might work better.
Old Sep 21, 2004 | 08:17 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
hey doward, you may have some options to add to your turbo kit, lol. you do the exhaust side of it and AM91 can take care of the intake side of things. just make on bit optional kit from both of you
Old Sep 21, 2004 | 09:30 PM
FbodTrek's Avatar
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
Awesome. Why don't you make a tapered 65MM spacer that will allow use of that TB on your stock manifold (yes I'm aware of the counterproductiveness)(is that even a word?). Funneling the inlet would increase air velocity, would it not?
Old Sep 22, 2004 | 10:24 AM
Car: 91 Camaro
i think that's a word... anyways, i don't think that the bigger TB would do much good with a tapered spacer because, yes the velocity would increase a little but i don't think that it would be enough to do much. the spacer would add a little more plenum volume too but, again, not much. my new intake will have about 150-175% of the stock plenum area. this should help top end power a lot.
Old Sep 22, 2004 | 10:33 AM
ok so what $$$ are we talking about here
not that it'll matter much either way b/c i'm in
Old Sep 22, 2004 | 11:04 AM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
awsome work
Old Sep 22, 2004 | 11:12 AM
vsixtoy's Avatar
Car: '87 Cam RS V6
Engine: Top Secret
Transmission: DYT700R4 custom inerts and conv.
Do you have a 3-axis milling machine at home?
Old Sep 22, 2004 | 11:16 AM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
all you gusy with all your nice tools, i wish i had the garage i wanted
Old Sep 22, 2004 | 12:07 PM
I wish i had a GERAGE!!!!
Old Sep 22, 2004 | 02:41 PM
Car: 91 Camaro
no, that would make things a lot easier though! the two biggest tools i used were time and patience!
Old Sep 22, 2004 | 05:09 PM
MakeitQuick92RS's Avatar
Car: 1988 Pontiac Trans Am
Engine: 383 Stroker
Axle/Gears: Borg Warner 9-Bolt, with 3.42 Gears
I think you should mass produce them...and sell me one!
Old Sep 22, 2004 | 05:17 PM
Doward's Avatar
LOL, you work like me man!
Hey, I don't even have a garage@!!! Why do you think the rain here in FL is delaying me so?
Old Sep 22, 2004 | 07:56 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
I wish you would just buy or borrow a Gtech computer and get us some numbers. It will be snowing in Florida by time you get a break in the weather.
Old Sep 22, 2004 | 07:58 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Couldn't you just build a spacer / adapter easier n just move the TB forward.
Might be easier to make a spacer with a hole big enough to open the blades them machine on the intake.
Old Sep 22, 2004 | 08:13 PM
Car: 91 Camaro
i'm making an intake with a bigger neck and more plenum volume to help out more. i'm also planning to port out the runners quite a bit. i have the top cut out of my new plenum so i can port that end of the runners while i'm at it.
Old Sep 22, 2004 | 09:13 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Nice work man. Just don't go running around shouting "I HAVE TB! I FINALLY HAVE TB!!!" when it's done
Old Sep 22, 2004 | 10:59 PM
FbodTrek's Avatar
On your motor, I BET! Keep us posted.
Old Sep 23, 2004 | 07:38 PM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
Nice work.
I don't mean to be negative but won't that size TB be overkill? Hell, anything bigger than a 52MM on even a modified V8 is overkill. I might do you more harm that good.
Old Sep 23, 2004 | 07:58 PM
Doward's Avatar
Dual 52s vs Single 65
Old Sep 23, 2004 | 08:34 PM
Car: 91 Camaro
yea, v8s run dual blades, i'm running a single 65. i don't think it will be overkill. even if it is, i'll make another one and go smaller
Old Sep 23, 2004 | 08:56 PM
Dale's Avatar
Engine: 350 S-TPI
I ran his setup (or as close as I could figure out) on DDD, and 65 isnt "hurting" him. However, much over 63 was it? Really didnt gain him much. I think it should work just fine. Gonna have to do some ecm tuning for sure though.
BTY, did you get my email AM91?
Old Sep 24, 2004 | 12:44 PM
Car: 91 Camaro
yea, chip tuning will be a must to get good performance out of it.
dale, you mean the email with the 'dyno sheets' or whatever, yes i did. thanks.
Old Sep 25, 2004 | 05:57 PM
Car: 91 Camaro
i'm working a bit more vigorously on the manifold now... i'm going to go kinda crazy with it though. i'm planning to cut the roof out of all 6 runners on the top piece and get the floors welded so that i can raise them about 1/4" then raise the roofs about 3/8" so that i make them about 1/8" taller inside than stock. then i'll grind the short side radius of the 90* bend. with all of this, the top part should flow tons better than before. then i'll have to get to work on another middle and lower...then heads! i'm planning to make this baby run a whole lot better than she ever has before! i'll get pics here and there as i go. you would be surprised at how horrible the inside of the plenum area is! there is, what looks like, a pile of 'left over' aluminum that was dumped in there during casting. it is horribley rough!
Old Sep 25, 2004 | 08:01 PM
Dale's Avatar
Engine: 350 S-TPI
Actually, I'm not. I did spend time to cut one open to see what was inside.
I had no ideas as to how to make it better, so I chunked it.
Old Sep 27, 2004 | 01:45 PM
Car: 91 Camaro
here's a pic after i cut the roof out of one runner. its going to be a lot bigger than that when i get done with it! i'm going to port the runners like this then weld the roof back in place. that bend in there is nearly 80-90*, i'm looking to straighten it to about 60* or so. that should help the flow a whole lot!
pwdbychevy
Apr 16, 2023 07:27 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Magman
Sep 13, 2015 08:43 AM
Chevy3shitty
Sep 1, 2015 09:22 AM
neekolzun
Aug 24, 2015 04:59 PM
