Ignition Coil relocation
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
I know KED85 & TomP have done it. Who else has moved/relocated thier coil to a cooler place?
Here's my version for ya:
Car: 1985 Pontiac Firebird
Engine: 2.8 LB8 HO
Transmission: 700R4 with OD
Axle/Gears: 10 bolt 7.625 open-factory 3.42
GM distributorless ignition system. The "coil pack" fires at the direction of the cars computer based upon input information received from the crankshaft position sensor. I agree very cool to see in an F-body.
Nice 3800 V6!
Nice 3800 V6!
Engine: 5.7 / 7.4
you might as well do a comlete 3.4 DIS swap liek Dale did in his show truck. THe 3800 came w/the pcm & harness, along w/the tranny (which is getting replaced soon). IF you do get the intakes/harness/pcm/egr w/tube, you could put it on a 2.8/3.1, but why not just get the whole THING
Engine: 5.7 / 7.4
I know of a COMPLETE 3.4 setup for sale , plus, if someone does do the full conversion w/an original VSS speedo, they'll have a lot less wiring issues than I have.
SO, does this mean that no ne else has done an aftermarket/stock coil in a non stock location????
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Oh yea I have an accell coil moved up the the cowl/fire wall lip.
It was as far as the stock wires would reach and nice n high away from all that heat.
Two bolt in the back of it are plenty to hold it steady.
